Question about 3M Vikuiti eXtended Resolution Video Screen XRVS-120 Monitor
Screen resolution recently upgraded older pc to windows vista now everything on monitor is big and the resolution is stuck on 640/480 wont allow me to adjust how can i fix this
  • michael_2fan Mar 01, 2009
    make and model of video card hp pavilion 533w model # p9859a integrated intel extreme graphics with up to 64mb shared memory
  • 3,940 Answers
You will need to load the Video card driver for Vista for the model card you have in the system. Once this is done, you will be able to adjust the resolution.
If you need assistance in finding the video driver, post the details of the make and model video card in the system.
Posted on Mar 01, 2009
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
The display of my monitor (hp w1907) is widened. A circle looks like an elipse. How can i solve this. please help.
It might tvhat there are no video drivers on the PC or there screen resolution is too big or too low
Screen Resolution Issue
Windows XP
1. Click Start -> Control Panel -> Display
2. Display Properties should appear
3. Click on the Settings Tab
4. Slide the Bar to the Left or to the right Making the picture almost a square
Windows Vista/ Windows 7
1. Click Start -> Control Panel -> Personalization
2. Click on Screen Resolution
3. Move the bar up or down until the picture turns almost a square
Or else reinstall a new video driver configure the screen resolution again
Hope this helps
May 24, 2011 | HP w1907 LCD Monitor
I have a new sanyo 32in flat screen for a monitor my pc loads up and it seems fine then when the log in screen should appear it goes black if i hook up a diff monitor it shows up
This most likely happens because the pc is using a resolution or frequency that is not supported by the tv/monitor. The resolution when starting pc is different than the resolution when logging in.
On Win XP right click on the desktop background, and choose properties from the pop up menu. Open the far right tab and change the screen resolution to 800 x 600. This is highly likely to work on the tv/monitor. [Vista or Win7 right click and choose personalize to get to resolution settings]
Connect to the monitor, restart pc, and you should be able to then see logon screen. Go back to the resolution setup screen and experiment with different resolutions till you find which works best for your display. You can pick a resolution and try it, then it will ask if you want to keep the setting. If you do not answer in 15 seconds, it will revert automatically to where it was a moment ago. So if the screen goes all funny or blank, just wait and it will come back.
Note that your display video card may not be able to support the optimum resolution you need, in which case you will be under utilising the screen. Everything may appear too big or stretched in one direction. In that case you will need to upgrade your video card to make full use of the screen capabilities. You should consult any documentation which came with the monitor to see what is optimum pc resolution to use, and bu video card appropriate to pc and monitor.
Nov 27, 2010 | Televison & Video
Low resolution of monitor
Right click on your desktop and select Properties (win XP or older), or Personalize (vista and windows 7), and select a higher screen resolution on the settings tab (XP), or by clicking "display settings" (windows vista or 7). If your slider is all the way to the right, make sure you have the latest drivers for your video card, or if the PC is older, you may need a new one that supports the resolution of the monitor.
Feb 06, 2010 | Acer AL1916W 19" LCD Monitor
Lost resolution windows vista upgrade on GX260
Hi there.
The optiplex GX260 does not support Vista, it only supports XP, Win2000, Win98 and NT 4.0.
Regards and thanks for choosing FixYa!!
May 27, 2009 | Dell OptiPlex GX260 PC Desktop
Resolution to big
Check your grahics card to make sure it supports higher resolutions. It may be that you have it already set to highest supported by your video card. Hope this helps.
Dec 27, 2008 | Envision H190L Monitor
My fonts are so large that I can't use some of my programs.
you could try going to "control panel" then personalisation and finally display settings look for the low high resolutions slider and adjust accordingly ( for windows vista)
this will adjust you monitor resolution so more items can fit on your screen
for windows xp i think from memory that it is "display settings" in the control panel you need i hope this helps in some way
Dec 22, 2008 | Acer Aspire 5100 Notebook
Screen resolution for LG 194wt
Hi, Afraid the only operating system now is windows 10 on any PC unless your using a Mac system. Once you upgrade to windows 10, everything will automatically set everything correct for you & you will be surprised how it will speed up your system! this is the best Microsoft release operating system they have ever made. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 11, 2017 | LG L1915S 19" LCD Monitor
Thoshiba SATELLITE A200-1Z3 Laptop
It could be that the screen is at the correct resolution, but the icons are just set to display larger (Vista allows this). Right-click on the desktop (NOT over any icons), and select "View". there you can select the size of the desktop icons.
Sep 04, 2008 | Computers & Internet
Default monitor
Hi, if someone has upgraded your version of windows the only way to go back to a older version is installing your windows xp home edition cd, only problem with that is when you downgrade you lose everything, so you will have to make sure its all backed up. in regards to the monitor, different monitors can support different resolutions, if you cant change it up any its quite possible you got a more basic one, All the best John
Mar 09, 2007 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
