Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
How do i change MTU settings?
How do I change MTU settings, so I can paly XBOS LIVE?
5 Suggested Answers
  • 35 Answers
SOURCE: I need to increase my MTU settings on my router for Xbox LIVE.
You can do that by configuring your router. Look for the default ip address of yoour router, it can be found in your router's manual. After you found it, run internet explorer and type in your ip address (ex. 192.168.10.1). There you o just enter your username and password and your on your way to the configuration process. Go to internet setup and under DHCP Internet Connection Type you can change MTU there. Just give it a try...
Posted on Jun 21, 2009
govinda123
  • 2263 Answers
SOURCE: I got it thru Verizon (Westell Model num.
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Posted on Jan 16, 2010
dexterlim29
  • 70 Answers
SOURCE: how do i change my 2wire routers mtu settings cant
you need to call your internet service provider because that is the firewall of the 2wire.
Posted on Jun 17, 2010
SOURCE: Need to change mtu setting
Having the same problem. I found this site that give information about contacting windstream and they will push a firmware update.
http://www.broadbandreports.com/forum/r25059010-Sagem-1704-Wireless-Router-MTU-Issues
Posted on Nov 11, 2010
How do i change mtu settingx
Hi log into your routers web page by typing the adress into internet explorer 192.168.1.1 then enter leaving the password blank, if blank password doesnt work try "admin" then click eack link until you find the mtu settings usually on "internet" or "Wlan" something like that.
Mar 21, 2010 | Buffalo Technology WHR-G54S Wireless...
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
I can't connect my Xbox 360 into LIVE because the
This option is available via the web interface under the WAN Settings screen.
Nov 29, 2009 | 3Com OfficeConnect Wireless Router
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
I need to know how to change my mtu setting
Xbox live is undergoing maintenance just wait it out,(tommorow.) ,
Jun 16, 2009 | 2wire HomePortal 1100 Router...
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
1,513 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
