Question about Ecoquest Breeze AT Living Air Purifier
I need to clean my Eco Quest Living Air purifyer plate...
Isn't there some way (peroxide or something) that your're supposed to use to clean the plate in the Living Air unit?
How do I clean the plate unit?
Clean with 50/50 ammonia/water, scrub with toothbtush, clean contacts with q-tip
Posted on Mar 06, 2009
Clean the plates with ammonia,something that leaves no residue....Mic
Posted on Apr 16, 2012
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Every time I clean the filter and the plate the ozone doesn't come on. I usually can fiddle with it and it will come on, but this time it didn't. What am I doing wrong and how can I fix it? this...
The plate is going bad. Sometimes it's just a bad part of the plate that has corrosion under it, try turning the plate and sliding in again. Sometimes that's all it needs. Sometimes it just needs to be brushed well, cleaned, and then blow-dried.
May 30, 2011 | Ecoquest Living Air Classic Air Purifier
I have the living air classic. When I turn it on,
The common things to check are the fuse, and make sure the filter tab is making a connection to the safety switch. You can find the fuse and the filter tab on the back of the purifier. Hope this helps.
Jul 02, 2010 | Ecoquest Living Air Classic Air Purifier
The Living Air O3 purifyer has stopped producing the purified air. The contact panels (2) have been clean as well has the entire unit on the inside. Fan runs and the little orange light is on in the...
Wow, the purifying plates have been is use for over 8 years! I think that your problem, try a new set of plates. You can contact the company at 800 989 2299 to order some new ones. Or you can email me stevelam at ecobusiness dot com and I can help you get some plates. Hope this helps.
Jun 17, 2010 | Ecoquest Living Air Classic Air Purifier
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
I have an ecoquest fresh air purifier and the end of a red wire was corroded so I replaced the end with a new one, but the unit doesnt seem to be producing any ozone smell or sanitizing. It seems as if...
That corrosion is oxidation for the lug connecting the grid plate.Metal contact fingers make contact on the plates metal grids.The same corrosion exists on those metal contact fingers and the plate itself. Clean the fingers,ensure good connections as the other wire connector spade for the other contact finger is probably compromised. You might de-oxidize the plate by soaking in pure white ammonia.At any rate,I agree about the quality of the machines and you might be faced with a small parts order from eco-quest.Do include the plate, a bulb and the bulb starter. I run 5 of these in a commercial setting and they are fairly enjoyable to work on.
Jul 25, 2009 | Ecoquest Fresh Air Living Air Purifier
Eco quest Breeze AT - Air purifier -Voltage varying, going haywire, unable to adjust controls
Call toll free 1-877-710-0057 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
May 27, 2009 | Ecoquest Breeze AT Living Air Purifier
Cleaning of Eco Quest?
I located this telephone number on Google for an Ecoquest dealer. I apologize for not having more info. Lakeland, FL‎ - (863) 816-7707
Mar 06, 2009 | Ecoquest Fresh Air Air Purifier
Unit has power but fan does not operate.
there is a micro switch that the metal rim of the filter that must contact in order for the fan to run tha unit to run. a bend or warpage in that metal filter housing will cuase contact problems with that switch causing it not to run
Jan 07, 2009 | Ecoquest Breeze AT Living Air Purifier
Lights won`t work,buttons on front and remote will not change the motor speed,stuck on low,ECO Quest Breeze AT.Thank you.
Did anybody solve this for you? The same thing happened to mine! All purifier lights come on but it's stuck on low!
Sep 18, 2008 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
319 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
