Question about Sony MDS-JE520 Mini Disc Player
Can't plug optical cable on MDS-JE500
I purchase an optical cable to transfer my mini-discs on my CD R recorder and the cable didn't fully engage on both machines.
I try the optical cable supplied with my sony mz-r37 portable mini disc recorder on both machines and it didn't fully engage in the optical out of mds-je500.
These optical cable are not one way i guess.Do i need to buy an optical cable from Sony?
  • HW_Dude
    HW_Dude May 11, 2010
    Did you buy TOS link compatible optical cable with plugs shown in the picture below ?
    President:
  • 1,285 Answers
Optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Posted on May 25, 2009
Recording backing tracks from computer
Standard audio cables or optical cables or coax cables.
Feb 15, 2014 | Sony MDS-JE440 Mini Disc Player
Not recording anymore
After you press the 'record' button the Minidisc unit is still in "pause mode" - you can hear the music and see the meters move, but notice that the time isn't moving until you press "Play" - then it will start recording. Is the time changing when you go to play it back? You might have left the MD in 'pause' perhaps?
Jan 30, 2014 | Sony Minidisc Mini Disc Remote Control...
Disc ejected and then retracted.
Check on the web for the fix. Many people had an issue with the Sony MDS-JE500 series MD units as the little lever switch that indicates that a disc is loaded goes bonkers and it might be as simple as 'adding' a non-sticky item to the lever. Do a Google search for 'mini disc switch fix'. Good luck.
Jan 25, 2014 | Sony MDS-JE520 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Hi have an mds-je500 minidisk player that stopped accepting disks, worked perfect one minute, says load error next each time i try to load, then says eject even though disk doesn't go all the way in....
The small limit switch for the disc in position typically goes bad on about 40% of all Sony Minidisc recorders. It is a $5 part, but will probably cost you $35 to get it installed.
Nov 05, 2010 | Sony MDS-JE480 Mini Disc Player
I have a Sony MZ-M200. I want to transfer live recordings that I have made of my concerts on MD to CD. I can load the recordings into the computer. How do I then burn them onto a blank CD?
You would have to use the Sony MiniDisc software to burn them as a standard CD. A better solution is to buy an actual stand-alone stereo "CD Recorder" and go from the MiniDisc player to the CD Recorder and it will record directly, including track marks if you make it a digital dub! Check into getting a Phillips audio CD recorder, and Sony still makes a stand alone CD recorder as well.
Aug 08, 2010 | Audio Players & Recorders
Got the je470 minidisc recorder but want matching cd and amp. which models are compatible? thanks
Sony models may have a bit of a family resemblance, but any CD player and any amp will work perfectly.
You will probably want a CD player with an optical digital output to take advantage of the optical input on the minidisc.
Feb 28, 2010 | Sony MDS-JE470 Mini Disc Player
Record on to mini disc
you can use optical cable / or mini plug to (Y) RCA jacks ...plug the optical cable to the back of a CD player or RCA jacks to your Reciever / Amp (output) to record
Aug 25, 2009 | Sony Net MD Walkman MZ-N505
SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
Jun 29, 2009 | Sony MDS-JE470 Mini Disc Player
I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Jun 24, 2009 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
292 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
