Question about LG LDS4821WW 24 in. Built-in Dishwasher
Just purchased and installed the LG LDS4821 dishwasher, instantly got the OE error code when we tested it. After following troubleshooting tips and calling customer service, error code still not resolved. Hose is not kinked, hose is not clogged (as no dishes have even been washed in it), and it's level. Does anyone have any idea what we could do to fix this problem?
  • 1,543 Answers
Try a test cycle with the end of the drain hose placed into a bucket. If the dishwasher does not pump out then, call for warranty service (In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000). If the dishwaser does pump out into the bucket check the entrance of the drain. (if it is draining into a disposer, there is a knock out plug which has to be removed) By the way, that is not an OE error, it is actually a DE (drain error).
Posted on Mar 01, 2009
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Keeps stopping and showing OE
Hi tpearsgolf,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. You can remove the filter, as well as the metalish sieve underneath it, check the sump underneath near the drainage holes, make sure nothing is obstructing the flow out of the machine from there.
If not successful, you will need to replace the Drain Pump.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jun 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Water is not draining.... OE symbol appears on display. Checked the connection up to sink and drainage out to garbage disposal. everything seems fine there!
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter by removing the bottom front access panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jun 12, 2011 | LG LDS4821 24 in. Built-in Dishwasher
My LG dishwasher is leaking from the bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Mar 17, 2011 | LG LDS4821 24 in. Built-in Dishwasher
LG model # LDS5811st stops and displays OE. What does that stand for
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Aug 22, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Oe code
1st) Blocked drain hose 2nd) Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3rd)Failing drain motor.
Gool Luck!
Apr 01, 2009 | LG Dishwashers
LG Dishwasher model # LDS4821 Constanly giving a OE error on the control panel
On the display a D looks much like an O. You probably have a DE error code which indicates a drain problem. Check your drain line, make sure the hose isnt kinked and the drain line is not blocked especially at the connection to the sink or garbage disposal. If that is all clear you may have a blockage in your drain pump....or the pump itself could be bad.
Jul 30, 2008 | LG Dishwashers
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
LG LDS4821WW 24 in. Built-in Dishwasher Logo
893 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
