Question about Frigidaire GLER642A Electric Dryer
Where is the heating element located. How do I get to it to change it?
  • 686 Answers
What brand and model #
Posted on Mar 01, 2009
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
on Mar 20, 2010 | Dryers
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
The heating element in the dryer doesn't glow and I can't locate the thermal fuse in order to change it. If it is the heating element, how do I change this part?
depending on your model, the thermal fuse will be located some where on the heat exhaust, some models its a small white or black disk
some models its a non resttable bimetal fuse
small round bullet looking thing
Oct 13, 2009 | Washing Machines
Heating element
Might I suggest this site if you are a do it your self.
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Mar 16, 2009 | Dryers
Changing heating element on a frigidaire dyer
If you dryer lint screen is located at the top of your dryer your heating element is going to located at the rear of your dryer. You will need to remove the back of the dryer to get to it. You will see a housing and the element is located in there. If you lint screen is located in the door when you open the door then your heating element is located in the front. This one is easier to get to. Simply remove the bottom panel under the door and you will see the heating element right at the front on the right hand side. Make sure you unplug the dryer before working on it. If you have any other questions feel free to ask and also please let me know if this was helpful for you. Good luck and glad to help.
Jan 22, 2009 | Kenmore 63942 Dryer
Location of heating element
The heater element on this washer ris behind the drum. You can change it from the rear or throught the top rear of the dryer. I hope this helps.
Jan 15, 2009 | Dryers
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
HEating element
The heating element is located in the bottom left corner. You will need to remove the drum for access. Once you have the drum out of the way, look for a square box with wires attached. There are 10mm fasteners that hold the heating element to the vent. Rome the screws, mark the wires and positions then remove the heating element. Before replacing the element make sure the thermal fuse and the high limit switches are not faulty.
Jan 10, 2008 | Amana DLE330RAW Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
81 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
