Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
Emglo compressor starts but stalls quickly after
My emglo compressor starts and then and soon as it does about 3-4 seconds later it just shuts off. it just won't stay running. plus it only starts when i spray starting fluid on the air filter i checked the fuel lines and they are not clogged.
  • 52 Answers
Its not getting fuel. There is a low oil shut off switch as well that go bad. most just bypass this unit. its connected to the on off switch as a 3rd leg. try that
if not check your fuel delivery. either the fuel line pet **** is closed/ clogged or a stuck needle in the carb is causing no fuel
Posted on Mar 02, 2009
Take off bowl to carb and poke a needle through center of carb where the threaded brass piece is plus clean sediment cup.make sure all other maint items are ok
Posted on Mar 29, 2009
Lefoo pressure valve leak
Where is it leaking from? If the unloader hisses for a few seconds when the compressor shuts off, it is working fine. If it hisses all the time when the compressor is stopped, it is still fine, but your in-tank check valve is toast. If it hisses when the compressor is running, you need a new switch.
Mar 03, 2013 | Emglo LEFOO Pressure Switch LF10
I have a dewalt emglo electric compressor around 6 months old with only 5hrs of use. i find as soon as the temp drops a few degrees like early morning summer weather it will not start it will turn over...
I have a gas engine powered DeWalt compressor. I don't know about yours, but is there an unloader that you have to switch when you are starting?
Next, did you inform DeWalt, this unit is almost new(ly rebuilt) and they should take some responsibility for it.
You know, it could be that the motor has a starting problem, (bad capacitor, bad start winding system).
Gary
Feb 11, 2011 | Dewalt d55151 factory reconditioned emglo...
Dewalt /Emglo 10 gal ,150 psi with 5.5 Honda GSX just shuts off sometimes ,some days it works fine ,some days it wouldnt work at all ,looks like something with gas ,it would shut off after pumpin tank...
I have an Emglo compressor with a 8 HP Honda motor. The motor has a low oil level shut-off switch in the crankcase. My switch failed intermittently and the motor would run sometimes and not others. There is a wire going directly into the motor crankcase. On my unit, the switch is normally open and when there is enough oil in the motor, it closes to allow the engine to run. If you can't start the motor, unplug the wire that goes into the engine from the connector. Then stick a wire into that connector and hold it to metal on the engine & try to start the motor. If that switch is the culprit, it should now start.
Be advised that running the motor without the switch in the circuit would allow the motor to be run with no oil in it.
Dec 06, 2010 | Dewalt Heavy - Duty 5.5HP, 10.5 Gal., Gas...
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Mar 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
Aug 31, 2009 | Electrical Supplies
Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Jan 03, 2009 | Dewalt d55151 factory reconditioned emglo...
Auto start will start car then turn car off 3 or 4 sec later.
on most remote start application a wire is installed in motor with one wire on the fuel injectors that wire reads rpm if its to high it stalls if to low stall so check wire get back to me
Dec 27, 2008 | 1998 Jeep Cherokee
Compressor will not shut off
The switch is bad, replace it, this should solve the problem.
Nov 17, 2008 | Dewalt d55151 factory reconditioned emglo...
Fan runs, but when compressor starts to run, you can here it trying to start up but then falls off and 30 seconds later it tries again and falls off again. It does not kick the breakers out. Duo Therm...
The compressor has a safety switch under the cover where the wires connect to it. That's what is kicking out. You should check the capacitor connected to the start winding. Check the wires where they connect to the compressor. A burnt off wire for the run terminal will cause these symptoms. If that's all good, it's being fed correctly on all 3 terminals, the compressor has stalled and will probably never start again. You can try a "hard start" kit, but not on a Scroll compressor (read the label). They aren't designed to survive that.
Jul 27, 2008 | Heating & Cooling
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
501 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
