Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elete 45862401 Quiet Pac2 front end washer that stops during the wash cycle. it flashes a f6 error code. The manual says it is a loose wire between the mcu and/or control panel,shipping bolts and/or shipping wire or tachometer error. Anyone have this problem?
  • jymcshn Mar 02, 2009
    Thanks i have checked the basket and it does rotate freely. It seems there is a problem with the control board on these units.
    There is also problems with the spider bracket rotting. There is even a class action suit being considered. Here are the links i have found so far.http://www.sheller.com/Practice.asp?Prac...
    http://www.youtube.com/results?search_ty....
    There are so many unhapp owners of these units it is amazing there has been no recalls. I have signed up for any information as the unit was very expensive for 1 it is not even 3 years old and Wirlpool/ Sears is screwing a lot of people with these things.
    Hope you will join..
    And thank you for your reply.
With the front door open, see if you can rotate the basket freely.  If not, most likely the bearing of the rear tub is worn out.  You will have to replace the whole rear tub which is about $300 for the part.  I am having the same issue with my Kenmore Elite Quiet Pak 2.  I'm contemplating with just buy a new top-load washer.
Posted on Mar 02, 2009
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
My kenmore washing machine is stopping mid-cycle and reading f6 on the panel
The F/06 error according to the official repair manual is a Motor Tachometer error . . the error is triggered because the main control board loses communication with the tachometer either a short in the wiring or a short in one of several other places. . The tachometer sits on the spindle of the motor and has two wires from the spindle to a wiring hub on the left side of the motor . . . two of the black wires are for the tach then feed to the MCU (Motor Control Unit) in the bottom left facing the washer which then feeds the info into the main control board which is at the top on the machine under the top cover. Some find that checking the connections with a volt meter is a starting point however in most cases you will not find issues with electrical continuity, the manual has the expected readings. The MCU is known to go bad in these machines so that would be the first suspect in resolving the error, however it could be the wiring, the motor or the main control board. The MCU costs around $200 so consider the possibility that it may not solve your issue. The error may even be sporadic only happening on heavier loads in the tub.
Nov 18, 2013 | Kenmore Washing Machines
Why does the washer stop during a load and "F 06"
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
The machine control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check Wire harness connections between the Drive Motor/Tachometer and the Motor Controller, and between the Motor Controller and the Machine Control
• The Drive Motor has failed
• The Motor Controller has failed
Jun 14, 2008 | Kenmore Elite 45986 Front Load Washer
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
852 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
