Question about Gateway 700 X PC Desktop
Where do you connect speakers on Gateway 700 tower
  • fmr888 May 11, 2010
    did the speakers come with the pc? because gateways are color coded. look on your orginal paper work and it will tell you which one of the 3 holes to use or put yor speakers up and install them. do a restart and let the pc pick a driver to get them to work. usually it is a green slot but the slots are marked as to which is the one you want
  • 3,940 Answers
Has 2 positives and negatives do I hook up to same terminals or seperate
The extra terminals might be there so you can bi-amp the speakers. (Drive the woofers and tweeters with separate amps). This also allows you to use only the woofers in the units as subs with different high frequency units; as in a home theatre system.
May 25, 2016 | Digital Audio Audio Players & Recorders
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
CD won`t ejcct from Gateway 700 computer tower
If you have a paper clip you can eject it that way , there is a small hole beside the eject button, I hope this helps you
Sep 23, 2011 | Gateway ONE GZ7108 All-in-One Desktop PC
I just moved my pc and not when I play sound I get nothing. which input do it use for the speaker jack. The computer is a gateway gt5662
Normally the ports on the tower are color coded. If you are using an analog audio output device connected through a standard 2 channel jack, the correct port to plug your speakers should be colred green.
Jul 02, 2010 | Gateway GT5662 Desktop PC
Have a Gateway 700 X Desktop that powers up, loads XP O/S, and then powers down after approx. 15 seconds and reboots. This goes into a loop repeating this process. Any ideas ?
This could be a result of you accidently hitting your desktop while trying to move it and you may have knocked the fan off. You can't hear if the fan has been disconnected but it causes the tower to overheat and it will shut off and reboot over and over and over. Please contact geek squad or go to your nearestn licensed retailer and see how much it will cost to replace the fan, if needed. It will be covered under warranty if you have one.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Gateway 700 X PC Desktop
My speakers stopped working after they were unplugged etc
Try the BLUE jack, then the GREEN jack. You won't hurt anything if you guess wrong. BTW, are the sub and speakers powered up? Pilot light showing they're on? Some speakers are powered by a USB port - any loose USB cables laying around?
Apr 18, 2017 | Creative Labs Audio Players & Recorders
I purchased a new Gateway. I can faintly hear the
Other than setting the volume controls in the software, make sure you plugged the speakers into the proper jack. Sometimes there are several output jacks, there may be a line out as well as an amplified out. If the speakers are not amplified, and there is an amplified out jack, try that one.
Jul 27, 2009 | Audio Players & Recorders
No sound from speakers
If you buy a 1/8 - 1/8 male on each end of cord and plug it into your stereo headset plug on your computer (probably the front of tower) and the other end to the analog in on the back of your ba735 will work great....... Good Luck,
Regi
Mar 20, 2008 | Boston Acoustics BA735 Computer Speakers
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
Gateway 700 X PC Desktop Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
