Question about Onkyo TX-SR606 Receiver
Pressing input selector button changes sound only, not vision.
Hi There,
I have a Onkyo TX-SR606 receiver which was working perfectly until my 8 month old daughter got a hold of the remote.
The problem that now exists is I cant successfully use the input selector buttons to alternate between CBL/SAT and DVD. When watching CBL/SAT, pressing the DVD button will activate sound only, not vision. In order to get vision I must turn the recievier OFF then ON again and I get both sound and vision.
The same happens in reverse. Once I am on DVD, pressing the CBL/SAT button will return sound but not vision. In order to get vision the receiver must be turned OFF then ON again.
While both work fine once the receiver is turned OFF then ON, I should be able to simply press the input selct buttons to transition between both easily.
I am using Red, Black and White inputs and I have NOT touched the cabling as I know there is nothing wrong with this set up.
I have spent two hours running through different things in the manual and have no idea how to fix the issue.
    Problem Solver:
  • 12 Answers
You're right, it definitely shouldn't be doing that! i know that your cables are probably ok, but it sounds like you might have a little software glitch or something going on. i would highly recommend upgrading your cables to HDMI. not only will you have fewer wires to deal with, you will also be upgrading both your sound and your video quality. in addition, the HDMI connections should be totally seperate from the other connections internally. you might luck out and find that only the analog side of things was afflicted. check out Newegg.com. you can get a 6' cable for $10.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2104300697%20117752939%201177412127&bop=And&Order=PRICE
only other option is to send the unit in for service.
Posted on Mar 01, 2009
No sound from new sony uhd tv on the Onkyo sr606 receiver when watching smart content like netflix.
Hi AB, best way to accomplish this would be to go from the TV's audio output to any open audio input on the 606 and just be sure that you assign the source to the input. If you require further assistance please feel free to give us a call at 800-229-1687, also note that we offer a trade in program if you are looking to upgrade to a newer receiver, please email me your current units serial number and I will advise if it qualifies for the program. You can email me at askOnkyo@us.onkyo.com, Thanks, JT
Dec 28, 2015 | Onkyo TX-SR606 Receiver
I have an Onkyo TX-SR606 connected via hdmi to a Sony Bravia 52" lcd screen. My inputs are a Panasonic DMR-EX77 dvd Recorder and a PS3 via hdmi into the Onkyo. All worked well for a month but now it takes...
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Jul 02, 2010 | Onkyo TX-SR606 Receiver
Hi I have a tx-sr606 receiver. Tv connection is
go to menu and select manual input selection if it is on auto input select
Jun 04, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 HDMI Input
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Apr 01, 2010 | Onkyo TX-SR606 Receiver
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
Onkyo ht-r960
I had the same problem at 1 year after purchase. I was upset. In addition to looking here, I also emailed the company. They took a month to get back to me, but their solution worked perfectly.
"Try resetting the unit by pressing VCR/DVR and the standby/on button at
the same time on the front of the unit while it is turned on. The unit
will display CLEAR and shut down. All settings will be erased. "
All my components connect without any problem now. Hope this helps.
Doug
Jan 20, 2010 | Onkyo TX-SR606 Receiver
Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Oct 19, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 power on default input setting and hissing sound
I had the same problem for more than a year but just lived with it. The solution is to reset the receiver to factory defaults. Page 96 of the owners manual, "turn the unit on and while holding down the VCR/DVR button, press the ON/STANDBY button. CLEAT will appear on the display and the unit will turn off". Problem solved!
Sep 21, 2009 | Onkyo TX-SR606 Receiver
Onkyo Tx SR606 Listening Modes "Not Available" Via Optical I have my Sky+ Box plugged directly into my TV with an optical cable from Sky box to my 606. I had no problems changing the listening modes untill...
check to see if the DIRECT icon is illuminated on the panel...if so, cancel the DIRECT function. This is only a thought, also check HDMI settings as well as optical mappings...
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
167 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
