Question about Sony Mavica MVC-FD81 Digital Camera
Replace disc drive mavica fd-200 - Sony Mavica MVC-FD81 Digital Camera
Replacing it is not necessary. Simply take it to a good camera dealer and have them clean out all the smoky weed coating and debris. You know, that hazy stuff that gets all over everything and fries your brain too.
Posted on Mar 08, 2009
How to reset default Sony Mavica MVC-FD73
you have to open the menu and choose to reset. There is not much settings to reset though. What is your problem.. might be other solutions if you have one.
Aug 23, 2014 | Sony Mvc-fd73 Mavica Fd Floppy Digital...
I can not locate where the memory stick is located on my Digital Mavica MVC-FD85. pleaase let me know
I'm sorry to inform you that the MVCFD85 Camera does not have a Memory Stick slot. The medium using in the Mavica FD camera is floppy disc.
The MSAC-FD2M floppy disk adapter can be used in some FD Mavica digital cameras.
With the help of the above mentioned Floppy disc adapter, you can insert a memory stick inside the adapter and insert it in to the floppy disk drive on the camera.
Jan 28, 2011 | Sony Mavica MVC-FD85 Digital Camera
Disc error C:13:01 on a newly formatted disc Sony mavica mvc cd250
I'll forward a link to a page where you can view the information to troubleshoot this issue.
Please click on the link to view the troubleshooting steps then follow all the steps and check if that helps.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C356202&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=91374119&stateId=1%200%2091370803
Thank you!
Apr 06, 2010 | Sony Mavica MVC-CD250 Digital Camera
Have no manual. Got a Sony Digital Mavica 1.3 Megapixel Model NO FD-85 at a garage sale that is giving me a format error with disc in and memory disc in as well.
It just wants you to format them in the camera before using. If you go to the support section of the Sony website, you should be able to download a copy of the manual to your computer.
Sep 25, 2009 | Sony Mavica MVC-FD85 Digital Camera
What type of disc do you use for a sony fd mavica?
Regular floppy disk, the one that used with computers.
Jun 07, 2009 | Sony Mavica MVC-FD75 Digital Camera
Sony mavica fd-88 says " NO FILE " when i put in the floppy
When inserting floppy the door won't close & I get disc error
Mar 06, 2009 | Sony Mavica MVC-FD88 Digital Camera
FD 200 MAVICa won't focus
Do yopu remember if the front (lens) area received a hit, even though with low force?
I am asking because in most MVC-FD cameras I opened to fix them about the same focus problem, I did find that an internal bracket that holds the lens assembly, it was bent due to an external force or hit in the front.
The bent bracket really was not the problem. The reason of the focus issue was that when the bracket was bent, the flat ribbon cable of the lens was pressed against a mounting screw, causing that the flat ribbon cable was damaged (punctured) affecting 2-3 traces of it, and preventing the lens to operate properly.
Repairing such problem requires to either replace the damaged flat ribbon cable, or the whole lens assembly.
You can get your hands in a broken camera with good lens assembly, and swap the parts.
Best regards,
Feb 25, 2008 | Sony Mavica MVC-FD200 Digital Camera
Installing memory stick into a Sony Mavica FD-83...
There is absolutely NO way to use a Memory Stick with the FD83 camera. The floppy adapter will never work with a FD83. The camera OS does not have the required driver.
Sep 13, 2005 | Sony Mavica MVC-FD83 Digital Camera
Mavica FD-88 Rattles
you have nothing to worry about. It's normal. The 3.5 diskette drive is a 4X speed and the noise you hear is normal. All FD83's and 88's will make noise and vibrate a little.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Sony Mavica MVC-FD81 Digital Camera Logo
75 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
