Question about HP Compaq nx6110 PC Laptop
Processor upgrade I have an HP Compaq nx6110. Recently upgraded to a 250GB HDD and 2GB Ram. Running Vista Business 32-bit. Currently has the stock 1.4GHz processor. I want to upgrade my processor. What's the best one I can get.
  • minijack87al Mar 07, 2009
    I've put to my hp nx6110 P4 2M cache 1,73GHz. Be careful because processors with 256 kB cache will not suit to this socket.
    I've also upgraded HDD to WD2500BEVE (250GB) however only 131GB are seen. Had you got similar problem when you changed your hard disc?
  • 741 Answers
Your CPU is tied into your motherboard. Only CPUs that are compatible with your motherboard will work. You can get your motherboard model from start>programs>system tools>system information. Once you have the model # then you can start searching for the CPU options. Good Luck.
Please rate this solution.
Posted on Mar 01, 2009
1). Have HP nx9500 with 512 MB memory 2). The screen is 1/2 size 3). Can I load Windows 7 and upgrade to 1 GB memory Hershall
To succesfully upgrade to windows
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • Jul 31, 2011 | HP Compaq nx9500 Notebook
    I have a compaq presario V6105NR and it currently has a 2.5 inch 5200 RPM 100GB hard drive, i am looking to upgrade to a 7200 RPM 320GB internal drive and all i wanted to know was if my system will support...
    Apparently the HP notebook model 441424-001 has a 200 GB HDD in it, I couldn't locate any specifications to what HDD size is the maximum supported by the BIOS of this laptop. I would say you are safe with anything under 500 GB.
    On the HP website there's only information about RAM upgrade: http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=3250961&
    Dec 12, 2010 | HP Compaq Presario V6105NR Notebook
    256 MB DIMM#1(DDR333) UPGRADE TO 2GB RAM in compaq nx6110 pc notebook
    You should be able to upgrade to 2 gig. Here are specs. Good Luck.
    512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
  • RAM configuration features 2 x 256 MB
  • Nov 20, 2009 | HP Compaq nx6110 Notebook
    Upgrading My hp530 laptop
    It is working.
    Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
    The HP 530 notebook is working OK.
    Sep 12, 2009 | HP Compaq 6720s Notebook
    Processor upgrade
    You can give it a shot. i just read on someone else doing that.
    Mar 12, 2009 | HP Compaq Presario SR1720NX (EL435AA) PC...
    Ram Upgrade
    Max speed supported for your mobo is: DDR2-533
    You will have to buy (4) 1gb sticks (2gb sticks not supported)
    To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
    Here is the specs :
    ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
    CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
    Chipset: Nvidia GeForce 6150 LE Chipset
    HD Bus:
    Front Side Bus options:
    Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
    Special notes:
    - Motherboard manufacturer's name: ASUS A8M2N-LA
    - HP/Compaq name: Nodus-GL8E
    NOTE: *Actual available memory may be less w/o 64 bit os
    Dec 24, 2008 | Computers & Internet
    Upgrading from 2gb to 4gb on a HP Compaq Presario SR2150NX
    Only with a new MoBo. There are two RAM slots that each support up to 1GB. I was in your situation recently. I upgraded from Vista to XP and it works fine.
    Aug 15, 2008 | HP Compaq Presario SR2150NX PC Desktop
    HP Compaq nx6110 PC Laptop Logo
    231 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
