Question about Dell XPS 400 PC Desktop
Won't boot on startup
When I turn on the computer, it simply goes to a black screen and asks me for my system password. I do not know the password. I have removed the battery and waited several hours and replaced but still the same. I tried OPHcrack, but it is not booting from CD. I have also tried my XP installation disc and it did not work either. What is my next step?
  • 3,940 Answers
The BIOS level password on a Dell XPS 400 is reset with a jumper on the motherboard. The intructions are here:
http://support.dell.com/support/edocs/systems/xps400/sm/syssetup.htm#wp1053659
Posted on Mar 01, 2009
Remove bios password
There should be a factory procedure for this. Anybody that can help You need to know first the brand and exact model of your computer to search for the right procedure.
Dec 25, 2013 | HP Computers & Internet
Black screen blue box saying
some one must have put in a boot password to your laptop,
follow this:
When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).
Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions.
If this does not work, try:
remove cell & start your pc you will here beep...beep...beep...
then turn off your pc & restore your cell.Start your pc and
password is removed.
there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost.
you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Dec 15, 2013 | Gateway LT2001u Netbook
Dell dimension 3100 win xp home will not logon or go to setup/boot screen, only goes staight to black screen saying TYPE SYSTEM PASSWORD AND PRESS [ENTER] but it doesn't let you type anything. Also will...
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Oct 20, 2013 | Dell Dimension Computers & Internet
Acer is going straight to a black screen after the acer logo in startup....it just shows a tiny blinking line. It goes no farther. I need help fast
Apparently your Acer cannot find the operating system. As soon as the Acer logo comes up, there should appear in one of the bottom corners "F" & a number should appear. Immediately start pressing that F number (top row of keyboard). This should take you to a boot screen. Scroll down to boot sequence. Hit enter. Make sure boot-up sequence is CD or floppy drive first, second should be HDD, then escape. Restart computer. Should then boot off CD drive. I am assuming you have an operating system (XP, windows, etc.). Let me know if this doesn't work.
Apr 07, 2013 | Acer Aspire 5734Z4386 Notebook
It keeps asking for current password i dont know it
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 22, 2013 | HP Mini 1000 Netbook
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
Forgot password for startup just has black screen asking for a boot up but dont know how to get around it
boot up ur computer,press f8, choose safe mode with command prompt. choose administrator. in the dos environment type (control userpassword), it tells you to enter new password.
Nov 14, 2009 | Compaq Presario Notebook
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Computer startup problems
Likely the hard drive is bad. I would suggest testing the hard drive or having a technician test the hard drive, replace it if it is bad and restore your operating system
Jul 08, 2009 | Gateway M-6750 PC Notebook
HP a1620n- Will not startup properly
try starting in safe mode then when it windows starts/full loads shutdown the computer. Then restart the computer-it should start normally.
Dec 01, 2008 | Computers & Internet
Computers & Internet Logo
294 people viewed this question
Alun Cox
