Question about Crossfire VR1000D Car Audio Amplifier
I am getting sounds only out of my tuner selection (radio) source
Kenwood kvd-815. I had this Deck for almost 4 years. All of a sudden, sound only plays when I have the radio (tuner) as the source. No sound comes out when I have Sirius Satelite radio, cd, or dvd. When I play the satelite radio, the display screen shows the channel and the name of the song thats playing but no sound. When I play a cd, the screen displays the track info and time ticker but no sound. When I play a dvd, there is no sound or picture but the screen displays a video time ticker and chapter display. I sent it in to Kenwood to get looked at. They called me back and said that theres nothing wrong with it and that it works fine. The only thing i didnt send to them is the black box tuner. What do you think it could be?
    Novelist:
  • 149 Answers
I would start off by doing exactly that removing the black box tuner out of the equation. The next question is did you install the black box or did you have someone else install it for you. If the box is not installed propperly then the audio outs could not be wired up correctly. Double check all of your connections. It could be something as simple as bad or no power to the box.
Posted on Mar 01, 2009
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
Stereo turns on but no sound
Is the sound source set correctly? There is a button to select the radio receiver, CD, AUX, USB, etc. That usually the problem when my wife can't get any sound out of my Kenwood!
Apr 12, 2014 | Kenwood Kdc-148 In-dash Receiver
Tuner problems
If you can hear music from other sources then it likely that it's the tuner that has the fault. Most tuners these days are one or two IC's. I would suspect them in this case. You can find them easily as there will lots of coils around them.
Feb 19, 2014 | Pioneer Audio Players & Recorders
I have been through the menu. i can't find a place to turn it on. the manual says it is a option by pressing the SRC button. All that shows is tuner and cd. Any help would be appreciated.
if this is a kenwood deck then by pressing the SRC will turn on the deck. tuner which would be radio and cd being cd player if the deck didn't turn on then it wouldn't show you any of that it would stay blank. for me to fully answer your help request I need to know the exact make and model of your deck. if there is no sound when you turn the deck on then try play with the volume as it may be turned down to 0 or 1 if there is still no sound then they didn't hook up your speakers to the deck. on the older kenwood decks there is a upside down triangle that is the SRC button on the newer decks it might be a rectangle button that says SRC. I hope i have answered your question, if so please vote and leave high marks. Thank you very much.
Aug 03, 2010 | Car Audio & Video
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Jan 26, 2010 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
My speakers arn't working with my new t.v.
Any sound from other sources ie. a CD/DVD unit, Tuner etc.? If so then the issue is the signal path fron the TV to receiver, What cableing do you have from TV audio output? Try standard analog 2 channel to the receiver tv in, be sure you select TV on the receiver mode,also check the TV sound menu options, some require that you disable TV speakers and use the audio line-out option fixed or variable.
Feb 01, 2009 | Pioneer VSX-815-K Receiver
Kenwood kdc-x592 No sound on CD and..
your amp turn on is hooked to the power antenna wire. Swap the blue wires and youll be good to go. Since the power antenna is not needed, when the radio goes off tuner, the 12V signal is turned off. and your amplifier will also then lose its remote turn on.
Reverse the 2 blue wires.
Dec 28, 2008 | Kenwood KDC-X590 CD Player
Kenwood tuner/graphic equalizer c-h6
sound output section trouble.can you remoove and shall we start rectifing the problem.
nuwan
Dec 04, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Get no sound from rear speakers WITH ipod
I have exactly the same problem - don't work with CDs either, just radio. Just installed the deck yesterday. Help would be appreciated. Have been through the manual front-to-back.
Aug 09, 2008 | Kenwood 50W x 4 Apple iPod -Ready MOSFET...
Crossfire VR1000D Car Audio Amplifier Logo
102 people viewed this question
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
