Question about Cuisinart Brew Central DCC-1200W, 12-Cup 12-Cup Coffee Maker
Leaks water out overnight
It seems to leak more when left overnight with water, but it also leaks when we make coffee during the day.
Cuisinart DCC-1200FR Brew Central 12-Cup
  • Anonymous Apr 12, 2009
    i've owned 2 - both leaked; my daughter owns one and it leaks - must be a design problem
    Problem Solver:
  • 10 Answers
I bet it leaks from the back, right? If it does, it has the same problem as my dad's.
You have a leak in the back of the holding tank. Fill it up, turn it around, without plugging it in, and watch for the water leak. If it's in a spot that you can see, then use some caulking to seal the leak. That should work. If not, it is leaking out from inside the plastic holding tank. Not much you can do but buy a new one.
Posted on Mar 01, 2009
  • Rico DOminguez Dec 18, 2011
    where can you get a new water tank?
  • Landrew Hammer Jan 20, 2013
    Wrong answer! The tank seal is worn. I use a pitcher to re-fill the water (no seal wear) . Remove the water tank, at the tank connection remove the seal cap by lifting, replace rubber seal (o-ring with groove), replace the cap (snaps in) done. Should last a year, buy several. Use a pitcher, I do.
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
Leaks everywhere
Make sure the lid is on the caraffe and just try to run plain water through. Although, it sounds like you might actually have a crack/leak. Return to store if possible or call Cuisianrt if it really is leaking.
Dec 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaks water from the bottom
Under warranty. Cuisinart will resolve. Thank you.
Dec 08, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Coffee leaks after it is brewed
The water reservoir on this mdoel is very close to the coffee reservoir - if excess water gets between the wall of the coffeemaker and the coffee reservoir, it will leak exactly as you described. Make sure no water spills out of the water reservoir when your pour it.
-Tha Mp3 doctor
Nov 23, 2008 | Cuisinart DCC-2000
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Leaks water
no b ut I have the same problem
Oct 22, 2007 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart Brew Central  DCC-1200W, 12-Cup 12-Cup Coffee Maker Logo
2,233 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
