Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Can you heat the pool and spa at the same time?
Spa is heating just fine, but pool heat is only "enabled" not "on". Can you heat both at once?
  • Jandy Master
  • 1,631 Answers
Are these separate bodies of water? Or is there some kind of equalizer? Like a spillway or a pipe between the two sharing water, if needed?
if separate, and they are sharing the heater, then in most cases, no.
if there is an equalizer, enable or allow that to operate. Turn on the spillover, or remove the plug at equalizer line or whatever method there is for your specific install. Then as the pool is heating, with water spilling into pool, that means your heated pool water is partially returning to spa. But... Unless you want pool to be at same 'Spa' temperatures, this may not be what you are looking for. Separate heaters (separate equipment) is the ultimate answer, to accommodate.
Posted on May 16, 2015
  • 125 Answers
Here is a link to the owners manual and users guide.
Aqualink RS24
Posted on Mar 04, 2009
How to turn spa heater with Jandy PDA?
normal running is pool mode turn to spa mode then enable spa heat it should work in not need more info
Sep 22, 2015 | Jandy Pool & Spa
How do I turn on the spa on AquaLink rs8
go down on controller to equipment highlight it will give you all your equipment pool mode spa mode then make sure your pool and spa heat is activated if you want it to be heated hit the button once then it goes to a 10 minute safety shutdown before the other mode comes on
Jul 24, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Error code 128r13
make sure spa setting heat is enabled
Mar 30, 2013 | Pentair MasterTemp 400HD - 400,000 BTU NG...
Jet pump and spa heat enable on their own
Check your time settings. It sounds like the Spa Mode has been set to run at given times and with heat enabled the heater will automatically turn on when the the spa is activate.
Jan 09, 2013 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Does not heat spa
if on controller make sure spa heat enabled
Jan 26, 2011 | Raypak 2100 Pool Heater Propane 206000...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
371 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
