Question about Nintendo Wii Console
Wii fit board, power button won't stay on
We synced it like it said, we have charged it overnight and it says fully charged, it just won't stay on
  • wiimomhi May 11, 2010
    Did it sync successfully? Are you using battery power or ??
  • Timothy  Lee
    Timothy Lee May 11, 2010
    How dose it turn off. Does it turn off while you try to use it or does it turn off as soon as you turn it on.
  • 33 Answers
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 03, 2009
On the wii fit board I press power button it flashes but won't stay on
Have you replaced the batteries and you also need to press the SYNC button inside the battery cover underneath the wii board and the SYNC button on the Wii console at the same time.
Apr 28, 2012 | Nintendo Video Game Consoles & Games
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    I can't sync my board to my remote
    You have to insert a wii fit game and bypass all the stuff until the game is ready to play.Open the battery compartment on the Wii board and open the large door on the front of the Wii console.Press the sync button on the board,then press the sync button at the top of the console compartment.The fit board light should stay steady blue.If it doesn't,try it again.When the fit board stays steady blue,it is synched.
    Jul 13, 2010 | Nintendo Wii Fit for Wii
    I have a wii fit board, when you power it up, it
    Had the same problem. It's a sync problem.
    First, best to double check you have fresh batteries.
    Next, turn the board upside down and remove the cover from the battery compartment.
    Open the small hatch cover on the front of your console unit.
    Now start wii fit from the disk menu item.
    Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
    While they are blinking, press the red button on the console (in the hatch compartment).
    This should re-sync your board and the light stays lit.
    Good luck.
    Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
    Wii fit board won't work
    Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
    The exact procedure is:
    • Even if the battery level is strong, try the following:
    Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
    Try these steps!
    1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
    Hope it helped.
    Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
    I can't set up my wii fit. When you hit the sync button the LED power never stays on on the board. HELP!
    Try first press and hold the red SYNC button on the Wii console (open the SD Card slot cover on the front of the Wii console, the button is just below the disc drive) for 15 seconds. This will clear all synced Wii things from the console.Now sync all back.Push the red sync button on the console, then open the batteries cover on your Wii Remote and push the red button there.Then sync also Wii fit.
    Nov 24, 2009 | Nintendo Video Game Consoles & Games
    Wii fit board wont sync
    get a new board or get it fixed,
    try different batteries
    dont put any unessessary weight on it
    dont stomp on it or jump
    be gentle with it
    get a new peice so no re-scyn
    make sure its not too close too the wii
    Apr 11, 2009 | Video Game Consoles & Games
    Wii Fit board not staying on
    Best suggestion is to make sure the game is fully loaded before pressing the power button.
    If it's not working, make sure you press the red sync button on the Wii Fit Balance Board AND the Wii Console.
    I know you tried new batteries, but make sure they are really NEW batteries (My experience is that the alkalines work best).
    If it still doesn't work, then you may need to contact Nintendo direct.
    Apr 08, 2009 | Nintendo Wii Fit for Wii
    Nintendo Wii Console Logo
    56 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
