Question about Farmall Cub Tractor Radiator
Steering is loose ' mostly in the steering gear
Is there a adjustment on the steering gear
someone told Me you have to drive the gear down on the sreering
shaft
could Someone help Me with this problem
thank you
  • 1,147 Answers
Look for a bushing it is wore
Posted on Mar 03, 2009
2005 GMC ENVOY 4.2L VIBRATION PROBLEM AT IDLE AND START UP OR ANY TIME NO ACCELERATING
Hello! This is a known problem that is addressed by the following Technical Service Bulletin...Guru...saailer
Subject:Steering System Moan, Groan, Shudder and/or Vibration Type Noise During Low Speed Turning Maneuvers (Replace Steering Gear) #04-02-32-007A - (12/01/2004) Models:2004-2005 Buick Rainier
2003-2005 Chevrolet TrailBlazer, TrailBlazer EXT
2003-2005 GMC Envoy, Envoy XL
2004-2005 GMC Envoy XUV
2003-2004 Oldsmobile Bravada
Short Wheelbase Utilities Built Prior to VIN Breakpoint 52123375
Long Wheelbase Utilities Built Prior to VIN Breakpoint 56137280
This bulletin is being revised to remove the 2002 model year and add the long wheelbase utilities. Please discard Corporate Bulletin Number 04-02-32-007 (Section 02 -- Steering).
ConditionSome customers may comment on a moan, groan, shudder and/or vibration noise while making low speed turning maneuvers. Customers usually notice this condition in parking lot turning maneuvers.
Correction
  1. Diagnose the power steering concern. Refer to Symptoms - Power Steering System (SI Document ID #670351).
  2. Replace the steering gear with a newly designed steering gear. See the parts information below. Refer to Power Steering Gear Replacement (SI Document ID #742314).
Parts Information
Part Number
Description
Qty
88965356
Gear Kit, Steering
(Short Wheelbase Utilities)
Gear Kit, Steering
(Long Wheelbase Utilities)
Warranty InformationFor vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E9740
Gear Assembly, Power Steering - Replace
Use published labor operation time
E2000
Toe, Front - Adjust
May 03, 2012 | GMC Envoy XL Cars & Trucks
2006 chevy silverado 1500 4x4,i cant adjust the power steering?with the bolt and lock nut with exagone screw?excuse my english,iam speak french.thank,luc
Why are you messing with it in the first place?? This is a job for someone who knows what they are doimg,,like a wheel alignment garage.
Mar 16, 2011 | 2006 Chevrolet Silverado
97 RAM 1500 4X4 replaced steering box and some
2 inches @ the steering wheel? i do not recommend tampering with the screw on the gearbox. that is for adjusting the sector shaft, usually only adjusted on high mileage gearboxes. since most of your driving is straight the gearbox worm gear wears out in that position, by adjusting it, it tightens up the gap in the gears the problem comes in when turning because it can be too tight on the ends of the shaft possibly binding up in your gearbox.and no matter what happens next it probably wont be good. try checking the couplings in the steering shaft. with the vehicle off, steering unlocked, have someone move the steering wheel left and right making sure not to move the tires, your looking to see play at all joints, couplings, or pivots. where you see one piece moving and the other not.
Mar 24, 2010 | 1998 Dodge Ram 1500 4WD
Excessive play after steering gear box and intermdt shaft replace
It is very important to take this back and have it looked at by the shop that did the repair. The steering box would come pre-adjusted. I'm afraid they may have left something loose...it happens. Try phoning them, they may even want to tow it or send someone out to check it. Driving with the steering box coming unbolted from the frame would be tricky.
Feb 22, 2010 | 2004 GMC Yukon
I have a 1984 jeep cj7 and it is having trouble turning, it feels like it is slipping and wont turn, like something is not catching, can anyone help
1. THE STEERING GEAR SHAFT ADJUSTMENT TOO LOOSE OR SHAFT AND OR BUSHING BADLY WORN 2 .EXCESSIVE GEAR WORM END PLAY DUE TO BEARING ADJUSTMENT 3.STEERING LINKAGE LOOSE OR WORN. 4.FRONT WHEEL BEARINGS IMPROPERLY ADJUSTED. 5 STEERING ARM LOOSE ON STEERING GEAR SHAFT. 6. STEERING GEAR HOUSING ATTACHING BOLTS LOOSE. 7.STEERING ARMS LOOSE AT STEERING KNUCKLES. 8.WORKING PINS OR BUSHINGS. 9.LOOSE SPRING SHACKLES.THIS IS 9 POSSIBLE CAUSES THAT WILL CAUSE STEERING TO BE TOO LOOSE.
Nov 10, 2009 | 1984 Jeep CJ7
1998 Ford 150 steering play
2-3" is a lot of play really. I would do the gear box adjustment and see if you can at least half that. That can not be fun to drive that way. If it comes back to reasonable play easily I would not worry about it unless it goes back to loose after the adjustment. I would plan for a steering box replacement in the future if this fails to adjust back to spec. How long will yours last? If I told you then I might be lying. :)
Jun 06, 2009 | 1981 Ford F 150
Steering box adjustment, how
Before you do this procedure, check the rubber or universal joint connector between steering column and the steering gear. If it's worn it will cause looseness and there's your problem. Otherwise, there is a threaded screw with a lock nut on the top of steering gear. Clean threads first. Put a large flat screwdriver on the screw and loosen the lock nut. Back it off several turns. Now, screw the screw down into the gear box. Not too tight though. Your actually jamming the gears back together. Back it off a 1/2 turn or so and run it back in lightly. Hold the screwdriver and tighten the lock nut. This is usually effective.
Apr 21, 2009 | Chevrolet Astro Cars & Trucks
2004 ford f350 4x4 dually is very loose while driving
Well it could be that you need to have the steering box properly adjusted tightened up a bit when you put the new steering box on it has to be adjusted by someone that knows how to adjust it properly or you might need to put a stabilizer shock on the front end or if it has one already replace it.
Mar 18, 2009 | 2004 Ford F350
Farmall Cub Tractor Radiator Logo
1,059 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
