Question about Hampton Bay AC434-WB 52'' Ponte Vecchio Weathered Bronze Ceiling Fan
Hampton Bay Ponte Vecchio ceiling fan light flickers
Hampton Bay Ponte Vecchio ceiling fan w/ remote was just installed. When lights are turned on, the down lights flicker once briefly and then turn on as normal. The up light operates normally. How do we fix the down light and eliminate the initial flicker?
Also, the fan comes with a solid-state remote device and the manual warns not to use a solid-state remote device. Why do you think it would come with a device that they warn you not to use?
  • keri_dever Mar 01, 2009
    Wow, thanks for the quick & free assistance. You rock!
  • 653 Answers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Posted on Mar 01, 2009
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Fan chain came out of Hampton bay fan
i would check the manual it will show you how to fix it. if you dont have a manual get one here
Hampton Bay Ceiling Fan Manuals
Dec 20, 2012 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Hampton bay
Always check the manual. I would recommend downloading one from here
Oct 12, 2011 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Ceiling to low for this product =(
hi! condenser is fault in fan! so only your fan run slowly! put high voltage condenser! then the run run fastly!
Jul 10, 2008 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Hampton Bay AC434-WB 52'' Ponte Vecchio Weathered Bronze Ceiling Fan Logo
572 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
