Question about Gaggia Italian Espresso Maker
Programming Gaggia Italcrem Commercial
I have a Commercial Gaggia Italcrem machine. I have difficulty programming it, A red light is flashing on both sides and there is no steam coming out only hot water. How can this be fixed??
  • 109 Answers
SOURCE: gaggia syncrony manual
Have a look at this site it should have what you need.
Posted on Jan 31, 2008
  • 5 Answers
SOURCE: gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Posted on Jan 14, 2009
  • 1618 Answers
SOURCE: Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Posted on Apr 06, 2009
  • 1618 Answers
SOURCE: My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Posted on Jun 06, 2009
  • 1618 Answers
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Posted on Oct 21, 2009
What does the red light descaling prompt light stay on? how can i know i have everything possible?
Fill it up the tank with descaler and start the machine on descaling. Leave it to trow all the liquid and must finish to the bottom,leave the machine to get AIR when descaler finished.Then the machine will stop and will tell you to put fresh water to clean . Fill the water tank to the MAX level and continue with the program. When the water is on minimum ,machine will stop,and the descaling process must be finished.
Good luck
Jan 11, 2018 | Gaggia Coffee Makers & Espresso Machines
Gaggia unica red triangle flashing at same time as green cup
Hi there My experience tells me that when a red light flashes on a coffeemaker it is one of three things: It needs water to be able to make more coffee The "bowl" that the compressed coffee goes in ids full and needs emptying It needs cleaning I would start filling the waterholder, Then emptying the compressed coffee holder If neither works, then start the cleaning prosess Best of luck and enjoy your coffee Kolbrun
Sep 18, 2013 | Gaggia Brera Coffee Maker
Does anybody know how to get rid of flashing red exclamation light on my gaggia platinum vogue?
It does not need to be descaled as this is not the descaling indicator...The water circuit needs to be primed. Turn the knob to the water drop and drain water into a bowl. Hold the water drop button down while this is happening until the red light turns green. Presto.
Oct 07, 2011 | Gaggia Platinum Vogue 90800 Espresso...
The led 27 flashing no stop
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jan 06, 2010 | Gaggia Syncrony Compact Digital Espresso...
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website:
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
Gaggia Italian Espresso Maker Logo
83 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
