Question about Dell OptiPlex GX280 PC Desktop
Nothing comes up on the screen
My PC turns on and a message on the screen comes on saying "no digital input". What does this mean? All connections are okay, what do I need to fix? Thank You!
grazzie08@hotmail.com
  • 3,940 Answers
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Posted on Mar 01, 2009
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
COMPUTER IS FROZEN..ERROR MESSAGE SAYS CHECK SIGNAL
So the message you get on your screen is telling you that there is no signal coming from the computer, Screen and computer are different parts, the screen is not your computer.
So this means that your computer is either not connected to your screen or not turned on. if it is turned on and properly connected, you have a hardware problem, take or have someone come over to inspect the pc in person.
Feb 03, 2013 | Compaq Presario 7478 PC Desktop
My computer comes on and a analog shows up and my screen turns blank
Is it a desktop computer? If it is, check the video cable in the back of the monitor, a blue video cable means analog input and a white video cable means it's a digital input. You may have a digital input and all you need is to press the button on the monitor that has a little monitor symbol and see if it switches input types. If you have the blue cable connected to the monitor and you still get no signal then you may have a bad video card.
Sep 03, 2011 | Computers & Internet
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
How do i repair my Philips gogear when nothing works?
Have you tried opening the Philips Device Manager and clicking the "Repair" button - because that's exactly what the message is asking you to do.
Mar 21, 2009 | Philips GoGear HDD6330 MP3 Player
Won't record...says din lock
I'd say you have the digital input selected. The player does not see a digital signal and gives such message.
Select the analog input and you should be able to record.
Hope this helps.
Jan 13, 2009 | Sony MDS-JE470 Mini Disc Player
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
No display
When you get the red and green leds lit it means the screen doesn't see an input signal and has gone to stand-by. That the red led goes off when you reconnect suggests a signal has been recognised by the screen but be very aware that it may not be a good signal. As you are using a PC input I will assume the signal is RGBHV, maybe you have the H and V swapped around? I would try another computer source into the screen.
You say you are using the digital harness, please explain exactly what this is.
Feb 18, 2008 | NEC MultiSync LCD4010 40 in. Television
Dell OptiPlex GX280 PC Desktop Logo
404 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
