Question about Kenmore Dryers
Dryer will not shut off.
The dial continues to move forward, never actually shutting off. The only way the dryer will not run is if you leave the door open and or unplugging it.
  • 686 Answers
Replace your timer
Posted on Mar 01, 2009
I have a Frigidaire Gallery Dryer # GLEQ2152ES1. Bought it used. No probles for several months. Moved to a different location. Dryer works but not heat and shuts off frequently. I replaced the control...
Hello - Since you have previously replaced the control board and confirmed that the high temp sensor is working fine, unit may possibly have a defective sensor, heating element, power supply or a communication problem with the control board. I suggest contacting a professional to move forward accurately. The technician usually warranties their labor just in case something else may turn out to be the root cause of your initial problem.
Oct 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Not heating/timer knob not turning . the dryer works but is not heating and i noticed that the knob is not turning therefore it does not shut off just keeps running.
HI. The timer device is responsible for initiating the heating cycle. If the dial plate is unable to advance, the heating circuit will not operate correctly, thus, preventing proper heating. Another indication of timer mechanism failure will be an un going cycle. You have stated that the unit Will continue to run, without stopping. This is caused by the defective timer device.
In most cases, the actual timer motor will Fail. This motor is , essentially, responsible for the forward motion of the dial plate.
I recommend to replace this damaged timer device, asap.
Jan 19, 2010 | Whirlpool Dryers
Dryer will not shut off dryer will not shut off
door lock or door micro switch
Nov 29, 2009 | Dryers
My dryer continues to run, it won't shut off. When the dryer door is shut it continues to run. When the timer is in the ''OFF'' position the timer runs through to the next cycle.
Hellow, If your dryer continues to run when in the off position you nee a new timer dial switch. I hope this helped you out. It would be greatly appreciated if you coud rate my answer. Thanks Mike-
Nov 03, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
