Question about LG LSC183VMA Split System Air Conditioner
Hi I have an LG S 24AWN / N 56 split system type room air conditioner which when turned on in cooling mode runs for about a minute then stops working with the error code CH 5 flashing. Has anyone got any clues on this one please. Cheers Roy1
  • 400 Answers
Have you cleaned the filter? Check the condensate drainpipe is not blocked by blowing into it from the outside.
Posted on Mar 04, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
No cooling LG
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
LG neo plasma air conditioner does not blow cold air
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Air conditioner remote
here are some icon meaning, this may help.
Apr 27, 2008 | LG LSC121PMA Split System Air Conditioner
LG LSC183VMA Split System Air Conditioner Logo
316 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
