Question about Dell OptiPlex GX280 PC Desktop
Montior wont turn on
I have a optiplex gx280 with a gateway monitor
i just got this computer off of ebay and went i turn it on the monitor stay black didnt see anything come up on it at all i have the key bord and mouse hook up i can hear the fan running on the computer on the monitor all i see is monitor self test , your monitor is work correctly , check computer power and monitor cable i dont know if the hard drive is working or not the fan is so load to hear anything
  • David Harner Mar 01, 2009
    power led is Solid AMber
    Diagnostic LEDs on the back of the tower no light at all
  • IQUIT May 11, 2010
    What does the POWER LED on the tower indicate? Is it Solid AMber? FLashing Amber? Are the Diagnostic LEDs on the back of the tower on? (ABCD ether Green Amber or off)
  • 3,940 Answers
Solid Amber Power LED is indicative of a Motherboard failure. Replace the motherboard.
The GX280 is one of many motherboards made during that time period that may have had capacitors that could fail due to a manufacturing defect if the capacitor. Check the capacitors on the motherboard to see if the tops are popped (there is a X engraved across the top of each capacitor, it the X is open, then the capacitor is bad.)
Posted on Mar 01, 2009
What is happening when computer light (when
cable connection issue between computer and the display? Adjusted the cable? Tried another monitor? Safe mode works? If safe mode works, you can try to update the driver of the graphic card.
Jul 08, 2010 | Dell GX280 Optiplex 2.8GHz Desktop...
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Dell gx280 wont run I installed new video card in pci e slot
I had exactly the same problem on my friends Dell GX280. It will only let you use the onboard card or the new radeon card not both together. In the end we had to buy a Radeon card that was made specifically for two monitors and disable the onboard card on BIOS. It would not let us use the two seperate cards in unison.
May 06, 2010 | Dell OptiPlex GX280 PC Desktop
Dell GX280 Optiplex wont start
Dell GX280 has been known to have issues with mother board because of bad capacitors that were sent out in them at that time. I have had so many issues with them when i working as an it. If you can open up your pc and look on mother board for expanded capacitors or even leaking. if they are not round it means that is the problem. Dells are very easy to open. On top and bottom there are kinda buttons u can press and just open towards the side that has lock for like locker lock and look inside.
Dec 28, 2009 | Computers & Internet
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
When the computer turns on i get nothing on the monitor and the monitor says it is in power save mode. plus the light on the optiplex tower stays orange.
when yo uget power save on you monitor it is telling you it has lost connection with the computer signal. make sure it is pluged in really good to the comp and to the back of the monitor. if it is in good then your video port or card is having a problem
Jun 23, 2009 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
124 people viewed this question
Alun Cox
