Back to:
Tags:
Lucien Piccard Men's 14K Gold Bracelet Watch
Lucien Piccard Da Vinci Automatique repair?
By Cornish - usenet poster
Can anyone recommend a good repair shop for this watch? I'm told it has a
"special" A.Shield 1800 mechanism with an offset something or other.
The watch is a "Lucien Piccard Da Vinci Automatique", 14k gold, roman
numerals at the 12, 3, 6 and 9 position and single bars at the remaining
positions. It displays day and date, vertically aligned at the 6 position.
At one time, the crown was a blue crystal (sapphire?) set in gold.
It was at my local watch repair center for about 2 years waiting on a part,
however when the part was finally located, it didn't help. Apparently,
there is a shaft of some sort that is worn out and will no longer hold a
gear that moves the hands. I think that's what the man said. The watch will
wind when I shake it but won't hold time. When I tried to wind it manually,
the crown and shaft(?) came out in my fingers.
I appreciate any suggestions/advice.
(yes, I've googled it)
Thanks
Dan
Cedar Park, Texas.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
maartenw
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks for the shop recommendation and this info.
Dan
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lucien Piccard Da Vinci Automatique repair?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Hart
Rating: 0%, 0 votes
AS1800 10 1/2 ligne manual wind, the cannon pinion is offset, actually
mounted on an extended pivot on the second wheel, it drives the minute
wheel which drives both the pinion that carries the minute hand and the
hour wheel that carries the hour hand.
AS1700, 1800, 1900 and 2000 series movments in both manual wind and
automatics were produced in the thousands and thousands, Mido among
other used exclusive version of AS movements, all more or less the same
layout with the offset cannon pinion
your watch may need a new second wheel or just have the cannon pinion
tightened up a little.
Thank You!
Solution #3
Not Rated (0)
Chandler
Rating: 0%, 0 votes
Was this Austin Watch & Jewelry? If not, maybe you could try them.
Be seeing you.
Thank You!
Can you Help with these Watches problems?
Watches
Need watch spare parts
Watches
how do i contact sector repair in Brazil ??
Watches
I have a Colibri Beam Sensor Lighter from 1980 how do I...
Watches
armitron watch band for model M525
Watches
I am looking for links for a DKNY mens watch the style...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
