Question about Magic Chef CYE2000 Electric Commercial Dryer
Take apart dryer to clean inside
Disassemble manual
  • 29 Answers
Http://www.repairclinic.com/0047_8.asp
try this web site i used it to take apart my washer!
Posted on Mar 01, 2009
How do I take apart to gain access inside of a kenmore elite dryer model 91073
Go to www.repairclinic.com and enter 91073. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Kenmore video showing disassembly.
Oct 22, 2017 | Kenmore Dryers
Dryer won't turn on. I have a lint fault light. Trying to disassemble to access the lower lint area for cleaning. Does anyone have instructions on how to do this?
You come in through the top. Don't try to take apart the front due to the fact you will lose parts and take hours to get apart and back together. What is the HE5 model number listed inside the door? I may have a manual.
APPLIANCE 911
Nov 29, 2015 | Dryers
Clean the inside of an amana range door
well they do come apart if cleaning is desired look around the outer edge caution tho as the glass can fall out .
Mar 18, 2015 | Amana AER6011VAS
Why do We have to dry clothes several times to get them dry?
It might just be time do do a little cleanup. No matter how good you are at cleaning the filter, lint is still gonna build in the dryer. themobilian_993.jpg
took the back dust cover off
While you are at it take the whole dang thang apart
speaking of a noise maker:
Go through it and do a good cleaning. No parts needed for that. then retry.
I have a service manual and more HERE
Jan 22, 2011 | Roper REX3614KW Electric Dryer
How remove front panel of frig gas dryer faqg7077kw
Hello there:
Here is how to disasseble the dryer
White/Westinghouse - Frigidaire style dryers- How to take apart....
White/Westinghouse, Frigidaire style dryers ( some 417.######## Kenmore dryers ) - How to take apart:
Disconnect power first In order to test and effect repairs on any product, you must be able to disassemble and reassemble the appliance. So lets start with disassembly on this dryer. Unplug the dryer. Get the top up by pushing in on 2 clips on either side as shown in this picture. We need to remove the front of the dryer next. There are 2 or 4 screws inside at the top on most of the older dryers that we need to remove. Once the screws are removed, you can pull forward on the front and lift the complete front off the 2 clips on the bottom of the dryer. Unplug the door switch wires and set the front aside.
if you need to further dissassemble it follow the next steps
Next step in disassembly is to remove the belt from the idler and the motor pulley. This is done at the rear of the dryer. Remove the 2 screws holding the inspection plate on the left rear of the dryer. Remove the plate. Look carefully at how the belt threads around the motor pulley and idler pulley so you can replace it. Remove the belt from the motor pulley. Return to the front of the dryer, grasp the belt in one hand and the front of the drum in the other hand. Lift up on the rear of the drum and pull forward with the other hand. There is a ball on the rear of the drum that rides in a socket located in the center of the back of the dryer. You are lifting the knob up and out of the socket. Look in the center of this picture for the socket. You have taken the dryer far enough apart at this point so that you can accomplish any repairs needed on this style dryer. It is not necessary to go this far for all repairs, but if you need to disassemble, you have the information.
Jan 09, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Hello I have a Kenmore gas dryer model# 1107282210 and the dyer seems to give off a little heat but then I it will stop giving of heat and the clothes will take very long time to dry. Now I cleaned the...
HI, Check the following to address this issue further.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task. The blower housing should be disassembled, and cleaned in this case.
2. Thermostat(Secondary Cause)- Highly unlikely in your case, but possible
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 17, 2009 | Kenmore 73952 Gas Dryer
I have a whirlpool dryer it heats and tumbles but its taking forever to dry
hi,
feel how hot the body of the dryer is mid cycle.
it should just be barely warm. if your laundry room has a door leave it open or cut a 1 by 1 foot hole in the door and put a grate on it.
most likely the outlet is clogged. take off the hose, pull it away fro the wall some, and let it run awhile unhooked from the vent, you should have substantial air output when its undone, (like a hair dryer). if its still hot with the hose undone its clogged on the inside and your going to have to take it apart and clean it all out. its not that hard to disassemble and clean, it takes about an hour. study it. dont run it untill its fixed. make sure you unplug it before you take it apart of course..
jm
Nov 29, 2009 | Whirlpool Dryers
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jul 22, 2009 | Fisher and Paykel DEGX2 Dryer
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Crosley CDE/CDG22b7
Please describe "rolling noise".
Oct 21, 2007 | Crosley CDE6000 Electric Dryer
Magic Chef CYE2000 Electric Commercial Dryer Logo
340 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
