Question about M-Audio StudioPhile DX4 Main / Stereo Speaker
How to get at fuse?
Studiophile DX4 does it have a fuse and how to? There is no power I asume thats the problem
My speakers keep shorting out would the power cord be a reason?
No, the power cord is not the issue. Tell us more about the symptoms
Oct 14, 2012 | M-Audio Studiophile AV 30 Computer...
Studiophile Av 20 Speaker has power but no sound
Do the level controls/volume controls move freely? or with difficulty? are the jacks correct for length and polarity? Do they "pop" when input is unplugged?
Mute button somewhere?
Jan 30, 2012 | M-Audio Avid Maudio 99005226600...
M audio studiophile BX8a deluxe has very hot back panel when on after a few minutes
There is a problem with the amplifier internal to the unit, most likely from the main power transformer. Return to the place of purchase, or a service center for repair/replacement.
Jun 27, 2011 | M-Audio Studiophile BX8a Speaker
I need to find out what amp fuses go into my M-audio studiophile AV30 speakers. please help.
The main speaker with the amplifier has very weak sound but the other speaker is working fine. Any suggestions.
Sep 23, 2010 | M-Audio Studiophile AV 30 Computer...
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
Hello, i have m-audio dx4 studio speakers. the treble on one side has stopped working. they are over the warranty and would possibly charge more than i'm willing to pay, i wonder if it would be something...
only if you can get the replacement part from m-audio. if you replace the tweeter with a generic one, it will ruin the sound of the monitors, and m-audio, most likely, will not let off of 1 tweeter unless you send it to them for repair.
Dec 27, 2009 | M-Audio StudioPhile DX4 Main / Stereo...
Fuse keep blowing
seprate the wires to get good sound...
Dec 09, 2008 | M-Audio StudioPhile DX4 Main / Stereo...
M-Audio DX-4 speakers blowing fuses
could be a problem with the wires? good luck
Feb 10, 2008 | M-Audio Studiophile DX4 Computer Speakers
M-Audio DX4 Studiophile Monitoring Speakers - Fried!!!
Hi Mr Goodrice
Happy Holidays
You may friied the capacitor of power regulator, or power suppy module. have to get to some place to make the change, or you have to RMS the speakers to US to replace. no other thing can be done. also you need a special conector and transformer to get the right voltage there.
good luck
Nov 20, 2007 | M-Audio DX4 Active Studio Monitors (Pair)...
M-Audio StudioPhile DX4 4'' Woofer
The "voice coil" inside the woofer must be rubbing against the "yolk" plate. Meaning = it is mechanically blown(damaged) to a point but electrically intact.
My sugesstion is to take out the damaged woofer and "google" for a mew woofer with the correct impendance and size and mounting holes. If you dont know thw impendance, then you should go with at least 8 ohms. More ohms = less risk of overloading the amp. whick can cause a fire!
Good Luck!!
Oct 20, 2007 | M-Audio StudioPro 4 Main / Stereo Speaker
M-Audio StudioPhile DX4 Main / Stereo Speaker Logo
48 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
