Question about D-Link DIR-625 (790069292637) Wireless Router
Can not connect to Internet wireless or through router to Ethern.
After working for one year, I have no wireless Internetconnection. Even using the Ethernet connection from the router will not work. I can print wireless. I can get on the Internet directly through the cable modem.
  • gmskolnik Mar 01, 2009
    The problem has been solved: It was an IP problem. A friend suggested disconnecting the Modem, Router and turning off all PCs. Then, in sequence, turn on the Modem, the Router, then the PCs. This worked, as simple as it sounds. As many times as I had turned off the Modem and router I had always left my PC on while I was doing it.
    Thank all of you who were trying to help.
  • Anonymous Mar 20, 2009
    the internet shows connected but in web pages
Call service provider (isp) to insure they have routers mac address. I cannot stress this enough
Posted on Mar 01, 2009
Wifi connecting
When creating a connection to internet, you need a point (read : router) which facilitates this. If you don't have a router in your neighbourhood, you can't connect to the internet. Even if there is one near you, you must be able to see it, by checking at your tablet for wireless connections. However, some routers are set to accept only connections, when a user ( your tablet) can provide this password everytime it tries to connect to the internet.
Schematic of internetconnection :
Tablet --- WiFi Router --- Modem --- Internet(provider).
Oct 18, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
Wi-Fi Password
if your able to connect to the router with a cable you can login to the router from a browser to 192.168.1.1 the default username is blank and password is admin.
you can go to wireless, wireless security and it will tell you the wireless password
if that does not work you can reset the router back to factory settings and reconfigure your wireless network name and password.
Nov 26, 2011 | Cisco Linksys WirelessG Broadband Router...
I have no internetconnection with my ps3. I have error 80028ea6 Who can help me?
Good day. If your ps3 is not connecting to the internet. Try to do this steps:
1. Check all of the wire and cable from modem to router.
2. Make sure all cables are tight
3. Try to reboot your equipment on this sequence, modem - router - ps3
If these didn't resolve your issue you need to contact your Internet Service Provider to check your connection. Possible the modem is not getting any signal. If your modem is working good then contact the router support to check the settings with your router. But usually your Internet Service Provider will be able to resolve this issues. Hope this information will help you in resolving your connection problem. Have a great day and thanks for using Fixya.
Jun 23, 2011 | Computers & Internet
For aboutfive years i have successfully had a orange live box installed in my home and, again successfully have 2 wireless computers. How ever my oldest computer doesnt have wireless option installed on to...
First be sure to check the drivers for your Netgear WG111 are up to date and correspond to your Operating System. It is important to note that there are three versions of the WG111. If you visit the Netgear's Knowledge Base site you can see the difference between the 3 versions (v1,v2 and v3) and select the one that corresponds to you. If you don't know what version you have look for a v1, v2 or v3 after the model name:
After you determine which version you have, let suppose its v3, click the link corresponding to it and download the Software Version 2.0.0 (Supports Win 7) if you are using Windows or the WG111v3 Mac OS Driver Version 1.0.0.0 if you are using a Mac. Once you download the file, run the executable file and install the driver/software for your device.
If your problem is not with drivers then youshould look at you Wireless Network Setup. Please Check that the router has a source of a working internetconnection plugged in correctly via an ethernet cable. Also, routers need fromtime to time to be rebooted. Try disconnecting the router from the power sourcefor 15 to 10 seconds and connect it again.
Post more details concerning your OS, the router you are using and what type ofinternet connection you have(DSL or Cable).
Mar 05, 2011 | NetGear WG111 802.11g/b Wireless Adapter
I have a CISCO Basic Wireless Router. Can this particular Router be connected to an HP Photosmart wireless printer? There is no WPS easy button on the router.
The router is capable of at least Wireless B (11MB) and possibly Wireless G (54MB) or Wireless N standard speeds. The HP Photosmart will do at least Wireless B speeds (and depending on which model - even possibly the faster "G" or "N" standards, too), so yes; it can be connected wirelessly.
You'll have to set up the the HP Photosmart printer the same way you set up other wireless devices to connect to the router. You'll need to input the SSID, Security Encryption Type (WEP or WPA) and associated security "Key" to match those settings that are in the router.
If you can't remember those settings, or never set up the wireless options, you'll have to access the Cisco Router's built in web set up page. Since you didn't include your particular model number, you'll have to look up this info at Cisco's web site yourself.
If you have trouble, include the model of your router and I'll see what additional info I can get for you.
Please rate this reply - thanks!
Jan 11, 2011 | Cisco Linksys WirelessG Broadband Router...
Cannot get a network connection using my linksys modelWRT54G2 WIRELESS ROUTER
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 03, 2010 | Cisco Linksys WirelessG Broadband Router...
I HAVE A WRT54G. I AM DROPPING MY WILDBLUE SATELLITE INTERNET SERVICE BECAUSE MY DIAUP IS FASTER AND MUCH CHEAPER. I WANT TO RUN THE NEW PHONE LINE TO A PC WHICH HAS A PHONE MODEM AND AN ETHERNET PORT. CAN...
The answer that he gave you is not accurate. In fact you can use your wireless over dial-up. This however takes a little work. You will need to setup internet connection sharing on your desktop with the modem. If you can get the sharing working, then you can use your ethernet card on your PC to transfer the internet back to your wireless router.
This will work, it has been a few years since I have done it, but I used it this way for several years.
Feb 01, 2010 | Linksys Wireless-G WRT54G Router
WRT54G, unable to install router
  • Since you have Internet connectivity through the router using a direct connection to the router, then you just need to access the router's setup page and re-configure wireless.
  • But first, check if the wireless light is on in the router.
  • Then, using a computer that is wired to the router, launch IE and type 192.168.1.1 on the address field.
  • It will then ask for the password. By default it is admin. Just click ok and it will lead you to the setup page of the router.
  • Then, on the menu click Wireless. Look for wireless network name or SSID. That is the name of your wireless network. By default it is set to "linksys". You may change it to a uniqune name and then save the settings.
  • Then, if you want to enable security in your Wireless network, click on Wireless Security.
  • Set security mode to WPA Personal and create your network key. It should be atleast 8 characters.
Hope this helps!
Dec 03, 2008 | Computers & Internet
DI 514 Wireless Router Problem
you upgrade new version firmware in your wireless router
Apr 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link DIR-625 (790069292637) Wireless Router Logo
241 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
