Philips Magnavox 27MS343S 27" TV Logo
A
Anonymous Posted on Mar 22, 2013
Magnavox 19MF337B/27 won't autoprogram
Trying to go from cable to antenna and display shows Start now When you enter nothing happens and i goes back and says channel not available
4 Related Answers
jamielwright
JAMIE L.WRIGHT
  • 75 Answers
  • Posted on Jun 01, 2009
SOURCE: My t.v. will not auto install the channels with my antenna.
Try the link.It may help.
http://www.ehow.com/how_2378904_ready-change-digital-tv-broadcast.html
Chi Chu
  • 8457 Answers
  • Posted on Nov 18, 2009
SOURCE: channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Anonymous
  • Posted on Dec 29, 2009
SOURCE: 19mf337b/27 has sound but no picture Tryed tv on
I threw out in the garbage
gopakumarg43
  • 76851 Answers
  • Posted on Jun 21, 2012
SOURCE: My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
2answers
I have a Magnavox 19MF337B, and it powers on and off a few times before staying on. After it powers on, I just get a white screen, and nothing else works. remote does nothing, and buttons on top do...
In some cases these TVs were to be returned for exchange. As costs were excessive. If this TV is out of warranty and you have no place to go with this TV, you might just have a hobbiest open the darn thing up. I would say you have a bad capacitor or two in the power supply. This is at its easiest repair. If not you may have a bad LCD panel and that is not worth replacing! Hope I could give a something to work with. Thanks for asking!
2helpful
1helpful
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
2answers
2answers
Autoprogramming
On many televisions with built-in tuners, you have to tell the tuner whether it will be connected to cable or antenna, since the RF spectrum is different for these.  Make sure you have cable selected (assuming you are connecting to the cable service) and then try the autoprogramming again.
2answers
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
