Question about Tomtom One XL GPS Receiver
Unit (tom tom 1xl) turning off
Charge unit on computer. Plug in to car the unit come's on approx.
1 hour or less it shuts off. Unit will not come back on. Take out
of vehicle plug into computer it will turn back on showing a low
battery
  • 74 Answers
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Posted on Mar 07, 2009
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
Unit will not come on
Make sure everything is fully charge and if you can try to change the battery to check if its a problem with the battery...
Hope that helps..........
Sep 30, 2008 | Tomtom GO 910 GPS Receiver
Can i charge my tom tom one europe on my pc computer
yes, your tomtom one can be charged via the usb cable provided with your unit.
you do not need to turn on your tomtom just plug it in for a few hours (tomtom does not recommend more then 6 hours)
bill
Dec 05, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom just stopped working
my tomtom does it now and then. solution is to take it to the car plug the car charger in to it, then press the reset button wait about 3 or 4 secounds and should come back on you don't have to remove your card. plging in to the computor does nothing it needs power when you press the reset botton
Sep 07, 2009 | Tomtom GO 720 GPS Receiver
Tom Tom turns on and then shuts off (cannot update my device)
You don't say what version tt you have but I would connect it to the pc and not turn it on. Just let it charge for a couple of hours. Then you should be able to turn it on and do an update.
Hope this answers your question.
May 02, 2009 | Tomtom ONE GPS Receiver
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Feb 27, 2009 | Tomtom GO 520 GPS Receiver
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
My unit will not turn on
if you have previously used the reset button ( or maybe even if you have never used it ) , make sure the little rubber cap that covers the button is allowing the reset button to spring back up. my reset button was being constantly held down, and quite possibly was causing an intermittant reset press during driving. take a flashlight and check before sending it back/in for repair. when depressing the reset you should feel a very small click, if you don't feel it, then your button is stuck- use a needle to move/remove the rubber cap and allow the button to return to its unpressed state. hope this helps somebody out there...
Jan 28, 2008 | Tomtom GO 910 GPS Receiver
Tomtom One XL GPS Receiver Logo
142 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
