Question about Kenmore Oasis 27042 Top Load Washer
How do i take off the center pole
I want to take it a part and put it back together so can you help me
    Genius:
  • 1,075 Answers
You might need a little help ;ie ;a pair of pliers or grips;turn antyclockwise, the top knob should come off easy.and away you go .adrian
Posted on Mar 01, 2009
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Apr 09, 2013 | MSR Family Tents
I need pitching instructions for a Great Outdoors Apollo 4 man tent
Take out all poles and stakes and tend and seperate.. First lay tent on ground and streatch out where you wish to pitch the tent. Then take stakes and place them in the four corners of tent through the loops so ththat when you hammer in the stakes the tent is nice and stretched out tightly. There should be two more loops on each side int the middle. When the tent is secure to the ground, take the poles that should have been put together and feed them through the hoops of the tent on the sides and top. Leave the top center parts of poles apart until you have poles through rest of loops and attatch them at the top of tent. front, back and center usually work pretty good for order. Doint middle last because it is the highest point. Hope not too confuseing. I camped a month every year for many years. You never forget.
Dec 23, 2012 | Sport & Outdoor - Others
Instruction for setup of American Camper tent 8x11
Posted on Jul 04, 2015
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
Jul 12, 2010 | MSR Family Tents
I don't know how to set up my travel lite crib bassinet
You're not alone. If you do every step perfectly then it's a breeze. Most of us are human and don't... This frequently results in a major pain.
Most travel cribs print the directions on the pad that lines the bottom of the crib. Unfortunately, this still isn't much help. I'm going to assume that you're like most of us- you've read the directions and you still can't get the thing to cooperate!
I fought with my Graco travel crib many times before I discovered a few secrets:
- Follow the directions precisely, even if a step seems a bit odd.
- If you get going on it and mess up (or it just won't stay up), give it up and start over again from step 1.
- Before you start, make sure that it's completely collapsed. It may look like it is, when it isn't. Here's how you check:
There should be at least one handle near the middle of each top pole that can be squeezed (longer sides sometimes have two). Feel your way across the top pole until you find each lever and squeeze it. This will collapse the pole into two (or more) sections.
Make certain that the poles remain collapsed as you pull the center handle (center of crib where matress will go) towards the sky and squish the whole thing together like you're putting it back in the box (or carrying case.) Now we're ready to start!
1) Gently begin to unfold/open the crib as you hang onto the handle in the center.
2) Continue to hold the center handle with one hand. With the other hand, lift each top pole until it locks into one "solid" pole. NOTE: This is trickier than it sounds! If the center handle drops even half-way down then you won't be able to get all poles to lock and you'll have to start over again.
3) Only after all four top poles have been locked, can you push down the center handle. This will spread the bottom into one flat piece and finish locking everything in place.
Good News!: It's all downhill from here!
4) Put a sheet on the "mattress", if desired.
Otherwise, just unfold it and place it in the bottom of the crib. There are some strange little velcro tabs on the sides of the mattress. These fit down the slits in the bottom of the crib and attach to the underside. This step is important as it keeps the mattress in place and helps to reduce the risk of suffocation.
5) Finally, assemble the canopy, locate all the little snaps on the side, and snap on the accessories.
Whew! Take a deep breath... you did it!
Congratulations on your baby! Enjoy!
Jun 24, 2010 | Graco Travel Lite 9001 Crib
How to put up a tent- ozark trails 16x12
I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
The fly basic basically clips on into holes on the blue dot poles.
It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
Have fun.
May 20, 2010 | Computers & Internet
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Jul 21, 2009 | Sport & Outdoor - Others
I took my seat and covers off my silver cross stroller to wash it and i have forgotton how to put it back together and i have lost the instruction manual, can you help with diagrams?
if it's the silvercross pop,put the back poles in first then the leg rests the button bits go in the holes,then the cover goes round the front of the pole to attach the slide on bit then the popper then put the hood on.
hope that helps.
Jul 11, 2009 | Silver Cross POP Jet Umbrella Stroller
How do I put together the pole caddy (4 shelf) with spring? did not come with instructions.
Put the poles together eith the spring section on the top. Otherwise, the weight of what you put on it will pull it down.
Jan 07, 2009 | ZENITH/BATHWARE 2114S CHR Wire Corn Tub...
Kenmore Oasis 27042 Top Load Washer Logo
64 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
