Question about Yamaha RX-V2600 Receiver
Not reading digital sound, only analog
I have an HDMI cable and Coaxial cable as inputs for digital sound from a cable box and a blu ray however the receiver is only reading stereo sound and not digital
    Problem Solver:
  • 12 Answers
Do you have the "B" speaker selector button pressed? i believe that it will only run in Stereo mode when running both at the same time.
Posted on Mar 01, 2009
How do I get the dvd player to work. I have it plugged in, but the one cable do I need it, even if they don't have surround sound? The coaxial digital cable. Do I need that to get it to work?
Make sure you have the audio plugs in the same input as the video. On the back of the dvd you will have a video and audio out. On the TV you will have to put these matching cables on the input of the tv. Once you have that you need to make sure the tv source is on the same input you have plugged into for this to work. If you have an HDMI input on your tv and an HDMI output on your DVD then you can use that instead of the three cables .
Dec 24, 2014 | Sony BDP-S1200 High Definition blu-ray DVD...
I can get sound from the radio and dvd, but no tv sound or video from dvd or tv.
It would all depend on which type of connection you are using. HDMI, Coaxial and Optical, are all digital outputs/inputs and not analog. Make sure you have switched whatever input you are using to analog or digital, whichever is appropriate. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 30, 2013 | Philips HTS3541/F7 - 5.1-Channel Blu-ray...
I have a kenwood VR405. I am useing a samsung blu ray and a cox cable box. both components are running directly into the samsung flat screen via HDMI. I am backfeeding digital audio to the VR405 via...
Josh, define the 'backfeeding' of the digital audio from the two HD components into Video 1. Those are ANALOG inputs on the VR405. You have two coaxial- and one optical-digital audio input you could/should be using.
I'm surprised you're getting ANY audio (much less digital audio) from the BD and Cable Boxes unless you also have an analog audio path coming in from (what?) the TV.
http://img.inkfrog.com/click_nelarge1.orig.php?image=100_2147.JPG&username=gceparts&aid=773763271
Sep 29, 2011 | Kenwood VR-405 Receiver
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
Jan 29, 2010 | Yamaha RX-V2700 Receiver
I need help setting up the cables on my home theater system. I have: 3 HDMI cables 1 Coaxial cable Yamaha 6250 receiver Samsung 7000 series LCD tv Samsung Blu Ray player Shaw Digital cable PVR box (similar...
2 hdmi inputs on samsung tv? different ways you can do it.if it was me i would run samsung blue ray to tv hdmi in,shaw box [if supported hdmi]to tv in, if not coax.
and i would sound out on tv to yamaha?
Dec 20, 2009 | Yamaha HTR-6130 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Connecting Sony BDP S550 Blu-ray player to my Denon 3802 receiver.
The only thing you need is an optical audio cable (toslink) connecting the Blu-ray blayer with one of the three inputs on the AVR3802. Then assign this input in the system menu to the input you like (e. g. DVD) and that should be it. The Receiver automatically detects the sound format from the Blu-ray and changes from stereo to DTS, DD5.1, 7.1 or whatever.
Regards
Thomas
Nov 01, 2008 | Denon AVR-3802 Receiver
Yamaha RX-V2600 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
