Question about Kenmore Oasis 27042 Top Load Washer
My washer shakes very hard
Using the number 7 it starts to shake and make very loud noises
    Scholar:
  • 106 Answers
One possibility is your have not levelled it correct. The rears are not adjustable. Tighten up the front fully then adjust from that point. When the washer is not on, try to move the machine with both your hands - it should not shake - then it is fine.
Another is that one of your shocks or springs could have come off. For this you have to open up behind to check and refit. Caution all this with the mains off the wall.
Spares:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
You can rate me.
Posted on Mar 01, 2009
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Washer makes loud noise (seemingly unbalanced) while spinning
Suggest making sure all four (4) screw leg adjusters are set correctly i.e. does it wobble if you shake like a "pin ball machine", when not in use? If yes, adjust the screw legs in each corner. To ensure the machine is sitting level and not able to shake... God Luck
Apr 21, 2011 | Kenmore Elite HE5t Washer
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
Washer was making a very loud shaking sound in the spin cycle, the noise stopped the spinning stopped and I smelled burning.washer will not spin
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 27, 2010 | Frigidaire Washing Machines
It shakes so violently, it knocked 2 holes in the wall. During the spin cycle, it also turned completely around backwards!! It's so loud it practically shakes the whole house.
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
Nov 06, 2009 | Frigidaire FTF2140F Front Load Washer
Agitator shaking and causing noise on Model #LST7233AWO
I have a GE washer......and the agitator is shaking(slack) and making loud noise while spinning
What should I do?
Jun 06, 2009 | Whirlpool Washing Machines
Washer shakes and producing loud noise
I would start with leveling it with a level. This should be easy to do. There are four post underneath that can be adjusted.
May 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Kenmore Oasis 27042 Top Load Washer Logo
49 people viewed this question
Sal De
fordexpert
Robert Rankin
