Question about Sony KV-35S42 35" TV
Tv Won't come on
Recent power failure at the house, with power surges. When power was restored, TV only blinks continuous in the standby indicator. Nothing else happens. I tried unplugging the Tv all day, without any result. Can you help?
  • Thomas Rehm Aug 04, 2007
    All I hear is a click, the the standby light blinks continuously. I have no real experience. Such a big, cumbersome TV I was hoping to try to fix it before I tried to move it. Thanks in advance.
    Continuous blinking on the indicator.
    President:
  • 3,130 Answers
If there are no blinks, do you hear a click when you try to turn on the TV set? If you do not, you have a problem with the standby power supply. Let us know how much electronic troubleshooting experience you have so I can decide on how to explain how to fix.
Posted on Aug 03, 2007
  • Larry  Dillon
    Larry Dillon Aug 09, 2007
    sorry sgregg, but those codes you listed are old, and yes while a few do still mean what it states, there are differant codes now for a lot of differant sets by Sony, such as the list you provided do not include the 9 or the 10 blink codes. you should check this out. http://www.techlore.com/article/15444/So...
    Sniper:
  • 133 Answers
I suspect a power board failure but to be sure i would have to know how many times your light is blinking as there is a code to it. please repost with number of blinks. This is a common problem with this brand of sony televisions as far as I can tell from what i have been reading online. If you are still under warranty you should contact Sony. If you need further help from an expert please let us know the number of blinks.
  • scott gregg
    scott gregg Aug 04, 2007
    Continuous Blink Once A Second, No Pausing means that there is No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
    here is a link. sorry about your tv it needs a new board.
    http://www.iwaynet.net/~nesda/SonyBlink....
The Timer/Standby LED light is flashing on the front of the TV. Can turn on TV with sound but no picture, TV shuts off within 5 seconds.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 08, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
My sony trinitron won't come on. I have a blinking light, it blinks 4 times fast. can you help me
Jul 17, 2011 | Sony Televison & Video
Red standby light is blinking 8 times on my sony bravia tv
I simply followed these steps with a surge protector
press the power button and hold up
Then hold up with the power button
then let go of up
and let go of power
worked with my kdl-55ex720
Jul 16, 2011 | Sony 55 KDL55EX720 3D LCD TV
I have a sony 65 in. sxrd projection tv that has the red power light blinking and the tv won't come on?
Jul 16, 2011 | Sony Televison & Video
Tv shuts off,standby light blinks 5 times repeatedly until tv comes backon
Mar 14, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My standby light blinks 7 times ?
Feb 25, 2011 | Sony KV-40XBR700 40" TV
The tv powers on and the standby light flashes, there is sound but no picture and the the tv powers off and the standby light flashes usually 6 times.
Feb 09, 2011 | Sony KP-57WS520 57" Rear Projection...
Standby light blinks 7 times no picture
Jan 04, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv won't power up
your regulator might be blown, & the red led is an indication your standby supply is still up. I can't recall the part #, its MX ### something, but there will most likely be a .22 ohm resistor feeding it, it'll be blown to
Aug 02, 2007 | Sony KV-35S42 35" TV
Sony KV-35S42 35" TV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
