Question about RCA RTD210 System
Volume doesn't seem to go up all of the way
RCA RTD217 5disc DVD home theater used to go to volume 40, but now only to 31. I had similar problems w/ another RCA 5.1 surr sound system and they sent this one to replace it. The old one eventually produced almost no sound. The remedy for the old one when it started to fail was to unplug the unit for 15 minutes. Then after that quit working, unplug it as well as all of the speaker wires from the unit overnight. I've tried both with this unit, and can still only get a 31 level. Praise the Lord it's still at 31, but if I could get 40 that'd be better as sometimes 31 can be hard to hear. Thanks for any advice you might have beyond what I've tried
  • 336 Answers
Lower the speaker levels then check what the master volumes maximum.
Posted on Mar 01, 2009
I can not get my RCA Blu Ray home theater to play what comes through on regular tv. It plays a dvd and will also play when using netflix from my ps3. I do not have any sort of cable box. My tv is a Sa
Gotta find an audio output from the TV and run it to aux input on the home theatre, select the aux function and it should work, if your tv has no audio out see if it has a headphone jack you can use as an audio out, can get a cable with 3.5mm headphone jack one 1 end and rCA red/white on the other, becareful when doin this as the audio output level froma headphone jack maybe controlled by the tV's volume itself. keep tV volume low and use the home theatre volume if your doing it that way
Nov 24, 2013 | RCA Blu-ray Home Theater With Vudu,...
Volume control on rt2370 rca remote doesn't work.
Hi there
I would try going into VOLUME through the MENU and find volume there and set it accordingly.
good luck
Kolbrun
Mar 26, 2012 | RCA Audio Players & Recorders
RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
I can't get the TV sound to play on the HT speakers
Ensure that you have an audio connection to your LG theater system from the TV, that is labeled as "audio out" or similar to "variable out" to an audio input on the LG system. You may use a pair of RCA type cables or sometimes known as composite audio cables. Then on the LG system, select the input to use that you connected your audio cables from the TV into. Disable the TV speakers. Decrease volume on the LG system, then increase the volume on the TV all the way up. You now can use the LG system as the master volume for TV.
Nov 12, 2010 | LG LHT854 Theater System
Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Apr 18, 2009 | RCA RT2500 System
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Rca rtd215 home theater system
some of them do this to save the speakers but try unplugging it over night and see if that reset it hop this inform you more.
P.S. I own two of them..
Mar 09, 2008 | Audio Players & Recorders
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
RCA RTD210 System Logo
155 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
