Question about Shuttle HOT-591P (MB591P) Motherboard
Mainboard does not recognize the PS/2 mouse
The mouse has been connected to one of the serial port connectors from the beginning. There is no indication that anything is wrong except the mouse no longer works. I've tried another mouse but it isn't responded to either.
I wonder whether or not adding a cable connected to the PS/2 Mouse Pin Header would work? If so, where I can get such a cable? (The same question applies to the use of the USB Pin Header.)
  • 59 Answers
Sounds like the serial port died. I have seen that happen before. You could try a DB9 to PS/2 adapter or DB9 to USB. The DB9 to PS/2 is cheaper of the 2.
Hope this helps.
Posted on Mar 01, 2009
Is there a way to put more than 2 Gigabyte of RAM onto an Abit LG-95Z motherboard?
No, the mainboard does not support more than 2 gb of ram.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?fMTYPE=LGA775&pMODEL_NAME=LG-95Z
CPU
  • LGA 775 Socket for Intel® Pentium® Dual-Core / Pentium® D / Pentium® 4 / Celeron® D Processors with 800 MHz FSB
  • Supports Intel® Hyper-Threading Technology
  • bullet_31.gif Chipset
  • Intel® 945GZ / Intel® ICH7 Express Chipset
  • bullet_31.gif Memory
  • 2 x 240-pin DIMM sockets support max. memory capacity 2GB
  • Supports Dual Channel DDR2 533 Un-buffered Non-ECC memory
  • bullet_31.gif Graphics
  • Integrated Intel® Graphics Media Accelerator 950 (Intel® GMA 950 )
  • bullet_31.gif LAN
  • On board 10/100M PCI controller
  • bullet_31.gif Audio
  • On board HD 7.1CH Audio CODEC
  • bullet_31.gif Expansion Slots
  • 1 x PCI-E X1 (Wi-Fi Accessories)
  • 2 x PCI
  • bullet_31.gif Internal I/O
  • 1 x Floppy Port supports up to 2.88 MB
  • 1x Ultra DMA 100/66/33 IDE connector
  • 4 x SATA 3Gb/s connector
  • 2 x USB header (support 4 ports)
  • 1 x FP-Audio, 1 x CD-In
  • bullet_31.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 Mouse
  • 1 x Serial port, 1 x Parallel port, 1 x VGA connector
  • 4 x USB 2.0, 1 x RJ-45 LAN connector
  • 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
  • bullet_31.gif Serial ATA
  • 4 x SATA 3Gb/s offer by Intel® ICH7
  • bullet_31.gif Form Factor
  • Micro ATX form factor 244 x 244mm
  • PCB Color: Blue
  • Aug 21, 2011 | Abit LG-95Z Motherboard
    My mouse keeps stalling and wont move the pointer when I move the mouse. Do I need a new mouse?
    clean out the bottom of your mouse even if its optical and try it on a different surface
    Feb 25, 2011 | Computers & Internet
    Does the labtec wireless mouse turn itself off when not in use
    You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
    Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
    Thank you
    Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
    My Trackman Marble FX stopped working after dealing with a virus. Never could get it to work, maybe I just wore it out. Bought a Logitech optical mouse but the left click is messed up. It locks and does a...
    It could be a bad Trackman or a bad PS/2 Port.
    1st test if it's the port by trying another mouse, or by trying this Trackman in another known working PS/2 port on another computer.  (don't forget to reboot each time you plug in a PS/2 device)
    2nd, you can try using a PS/2 to USB adaptor.
    These two have great reviews...
    $12 TRIPP LITE USB to PS/2 Adapter Model B015-000
    http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812120006
    $20 SIIG JU-ACB012-S2 USB to PS/2 adapter cable
    http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812191021
    Best of luck getting that wonderful Trackball working again!
    ~Andrew
    EmpoweringSolutions
    Feb 20, 2009 | Logitech Trackman Marble FX Trackball
    Mouse wont work , I have put new batteries in & have also looked in control panel which says it is working ... Red light is on. HELP...
    Recommendation:
    • Make sure that the mouse is connected physically to the correct port and that it is not loose.
    • Check the mouse wire to make sure it has not been excessively twisted, bent or damaged in any way.
    • If you have another mouse that you can try in place of this one, try swapping them and see if the problem goes away. Similarly, you might want to try your mouse on another PC and see if it works. (Remember that drivers are often specific to certain types of mice; you want to swap with another mouse of the same type, using the same interface, either serial or PS/2).
    • If this is a new PC, check this section for troubleshooting possible general problems. In particular, there may be a loose or incorrectly connected internal cable to the COM port that you are using for the mouse.
    • If you are using a PS/2 style mouse, make sure it is not connected to the (identically-sized) PS/2 keyboard connector. This of course will also make the keyboard not work properly.
    • If you are using a serial mouse, you may have a problem with the serial port itself. Resource conflicts and other problems with the serial port are fairly common. Look here.
    • If you just upgraded your motherboard and now your mouse is not visible, a likely cause is that you left the old cables that attached from the serial port connectors to the motherboard headers in place. These cables are not universal, and you might now have the wrong kind installed for your new motherboard.
    • If you are using a PS/2-style mouse, remember that the mouse uses IRQ12. In some situations, this may cause a resource conflict with another device. Check here for more on resource conflicts.
    • If you are trying to use a PS/2-style mouse on a serial port, or a serial mouse on a PS/2 port, you must use a so-called "combo" mouse. These are specially designed to be able to handle the different electrical signals that are used by the two different mice. Some mice will fit the adapters physically but will not function correctly because they cannot handle the different signaling levels required;
    Nov 04, 2008 | Computers & Internet
    Motherboard
    Part / Feature Specification / Support Motherboard description
    • Motherboard manufacturer's name: MSI MS-7174
    • HP/Compaq name: Graphite-GL8E
    CPU/Processor
    • Socket: 775
    • Supports the following processors
      • Pentium 4 600 series
      • Pentium 4 with HT
      • Celeron D
    Front-side bus (FSB)
    • 800 MHz (Pentiums)
    • 533 MHz (Celeron D)
    Chipset
    • Northbridge: i915GV
    • Southbridge: ICH6
    BIOS features
    • The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral devices and expansion cards of the board automatically.
    • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
    Form factor
    • Micro-ATX form factor: 9.6 in x 9.6 in
    Memory
    • Dual-channel memory architecture
    • 2 x 240-pin DDR2 DIMM sockets for up to 2 GB non-ECC DDR2 533/400 SDRAM
    • Maximum HP/Compaq approved memory is 2 GB
    Expansion slots
    • Three PCI
    Video graphics
    • Integrated
    Serial ATA
    • 2 SATA connectors
    • Each connector supports 1 serial ATA-150 disk drive
    Onboard audio or audio card Integrated Intel High Definition(TM) audio (Azalia)
    • Realtek ALC 880 CODEC
    • THX certification support
    • 8-channels for Full Dolby 5.1/6.1/7.1 surround sound support with Dolby Pro Logic IIx
    Onboard LAN
    • Intel 82562GT
    • 10/100Mbps Fast Ethernet LAN controller
    Back panel I/O
    • One PS/2 mouse port
    • One PS/2 keyboard port
    • One VGA (monitor)
    • One Parallel
    • Four USB (2.0)
    • One IEEE 1394a
    • One RJ-45 networking port
    • Six audio ports support 8-channel Azalia audio codec
    • One S-video out
    • One SPDIF in/out
    Internal connectors
    • One 24-pin ATX power connector
    • One 4-pin 12V ATX power connector
    • One IDE connector
    • Two SATA connectors
    • One floppy drive connector
    • CPU fan connector
    • PC fan connector (also known as duct or chassis fan)
    • PC indicator LEDs / power switch / reset button connector
    • Optical drive audio input
    • Auxilliary audio input (may be used for line input)
    • Front panel headphone and microphone connector
    • Two USB headers supporting up to 4 additional ports or devices
    • One IEEE 1394a header supporting one 1394a port
    Jul 27, 2008 | Compaq Computers & Internet
    Hello
    check mouse ps/2 port connector pins they can be twisted or blunt.
    May 03, 2008 | StarTech.com USB, USB 2.0, Parallel,...
    Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
    You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
    If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
    Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
    Serial port?
    There are two basic ways to work around this situation: * Use a PS/2 mouse instead of a serial mouse. Using a PS/2 mouse will free up your serial port so that you can connect the camera to the computer. Check the computer's documentation to see if this type of mouse is available for your system. * Enable MouseKeys on your computer. MouseKeys allows you to use the numeric keypad to move the mouse pointer and to click, double-click and drag. After enabling MouseKeys, you can disconnect the serial mouse and connect the camera to the computer. Click Here to see an animated demonstration, or follow the instructions below. To enable MouseKeys: 1. From the Windows toolbar, select Start > Settings > Control Panels. 2. Double-click the Accessibility Options icon. 3. Select the Mouse tab. 4. Select Use MouseKeys and change settings, if desired. 5. Click OK.
    Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
    Serial port?
    Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
    Shuttle HOT-591P (MB591P) Motherboard Logo
    99 people viewed this question
    Top Shuttle Computers & Internet Experts
    David
    David
    john smith
    Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
