Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Changing oil How do you drain the oil on the Craftsman lawn tractor??
4 Suggested Answers
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
  • 582 Answers
SOURCE: does a 19hp crasftman lawn tractor have a oil
IF IT HAS AN OIL FILTER IT WILL BE VISABLE FROM THE OUTSIDE OF THE ENGINE. IF THE ENGINE IS A SINGLE CYLINDER IT SHOULD NOT HAVE A FILTER TO THE BEST OF MY KNOLLAGE THEY PUT FILTERS ON THE TWIN CILINDERS
Posted on Sep 23, 2009
Removing oil plug on MTD 760-770 lawn tractors
Here's a link to the manual. With a picture of the drain plug its hard to say.
Jun 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i remove and replace the oil filter on my model 917.271910 craftsman tractor
Down on lower left side of motor is a pipe nipple about 2 inches long with a black plastic cap . Half twist it by fingers and pull off.Oil should drain.
Apr 30, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
Apr 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor 1000, oil chg
there is no filter. but when you drain the oil. start by adding a 1/4 quart and check the level. if still low keep adding (little at a time) until it reaches the full mark on dipstick...good luck
Apr 03, 2010 | Garden
Sep 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What weight oil should I use for 16 horsepower craftsman engine?
It all depends on the engine you have...all engines except for KOHLER can use straight 30 and Kohler uses only 10W30.
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
141 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
