Question about HP OfficeJet 4215 All-In-One InkJet Printer
HP 4215 All in One - check right cartridge error
My HP4215 all in one ink ket has an error "check right cartridge" and even with a new cartfridge, it still has the error. I checked the contacts inside, and all looks OK (no lint or dust). I tried to reset to factory defaults, and that did not work either. Tried clean print head and test alignment, and also no improvement. On the check alignment, the first pass comes through (black and white only) but the printer will not then feed from above.
  • Anonymous Apr 10, 2009
    I have the same problem. I get a message that says the right printer cartridge is incorrect though it is the correct HP cartridge for this printer. What should I do?
  • 238 Answers
As the manual of this device says
Check the print cartridge to make sure
you have properly removed its packaging. Being careful not to touch the gold-colored contacts or ink nozzles, make sure you have gently pulled the pink tab to remove the plastic tape.
Here is the link to a manual of this device. Hopefully, it will help.
Posted on Jun 23, 2017
SOURCE: Hp Office jet print cartridge error
I have a 7410 that is 16 months old with the same problem. It is not a broken spring. Spent over an hour on chat attempting to trouble shoot. HPs only solution was to sell me an "upgrade" for over $300 (which is more than I paid for this piece of junk.)
I expect "top of the line" products to last quite a bit longer than that. The worst thing is that with this error popping up, it is absolutely useless for anything else like scanning or outbound fax.
It should be called an "all or nothing" printer.
Posted on Feb 29, 2008
  • 518 Answers
SOURCE: lost my disc hp4215
You can download the drivers from HERE .
That should fixya...
Posted on Apr 04, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 5 Answers
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Posted on Nov 28, 2008
SOURCE: Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
Posted on Dec 13, 2008
How do I install my ink cartridge for a hp officejet 4215 all in one
Turn on the HP printer. Lift the printer cartridge door, which is the right side of the printer, revealing the black and color ink cartridges. Push down on the front of the cartridge you need to replace and pull it out slowly. Unwrap the new ink cartridge and peel off the tape. Insert it at an angle into the cartridge slot. Apply gentle pressure until it clicks into place. Close the cartridge door and press "OK" when prompted.
HP User Manuals: HP Officejet 4215
Hope this helps you :)
Mar 07, 2012 | HP OfficeJet 4215 All-In-One InkJet...
Will 27 work on 4215
HP 27 cartridge is not compatable for this printer. Supported cartridges are :
Back : HP 56
Color : HP 57 , HP 28
Photo cart : HP 58
May 08, 2010 | HP Officejet 4215 All-in-One Color Photo...
4215 cartridge error
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP 4215 all in one printer. Cartridge error
Hello Barry
It is odd that the machine is not telling you which one.Mine usually does.Okay
the best way and cheapest way for you to figure out which one it is, the unit takes a HP 56 and HP 57,which are very common carts,used in the HPs today,If you can get your hands on two
different carts and exchange them around you will be able to find out which one it is.They do not necc. have to be full ones.Once you find out which one it is get a new one.I would be willing
to take a guess it is your black one
Feb 06, 2010 | HP Officejet 4215 All-in-One Color Photo...
I lost the disk for my HP4215 printer fax machine
Put the model number in to the HP website and you can download the full install suite
Oct 05, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Lost my disc hp4215
Apr 04, 2008 | HP Officejet 4215v All-in-One Printer
HP OFFICEJET 4215 cartridge error
Try this while standing on one leg.
1. OPen ink caridge lid.
2. Remove the affected cartridge.
3. Close lid
4. Try to print. This will fail, but that is ok.
5. Open the ink cartridge door again.
6. Remove the other cartridge.
7. Unplug the unit.
This can be risky and I asume no responsibility for pressng too ******* the contact points, havng too much alcohol, using the wrong kind of alcohol, or not using alcohol or other such problems that can occur.
8. Using ONLY alcholo lightly brushthe contact points
9. Lightly clean the cartridge cotact points.
10. Plug in the unit
11. Install the cartridges.
12. Go through the alignment process.
13. Switch to the other leg, those with one leg only are exempt.
14. You just might be ready to print again.
I know this sounds crazy but this just worked for me.
Feb 01, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 4215 All-In-One Error: Remove/Check Left Cartridge?
Apparently HP meant left cartridge when looking from the back of the printer. I replaced that one (B/W), problem went away. Sort of dumb...
Jan 05, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
4,855 people viewed this question
Ben Johnson
