Question about Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive
I can't access data off my portable hard drive (model HD-337-U2C)
I have a Mobile Disk External Data Storage 250gb (model HD-337-U2C) and I can't access the data. I plug it in, the green light comes on, place the usb in the laptop, but in my computer, there is no portable hard drive. I've looked everywhere and it can't locate the hard drive. It has heaps of valuable photos I can't access. Thanks
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Transcend external harddisk 250gb not accessing windows7 and asking for formatting and also immediate disconecting. How can i solve it? and how can i access it ?
Copy any data on the disk onto some other media using another computer (I know you have friends running XP and Vista) then just format the hard disk.= as requested by 7.
Sep 01, 2011 | Transcend 2.5 StoreJet Portable Shockproof...
Hi:I have a Beyond Micro, model HD 337 U2C. Suddenly after no problems I can't access about 3/4 of the content of the hard drive. It sounds OK , but just is not functioning. If you can't fix the...
if you can access your beyond micro hard drive
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Feb 05, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hitachi 250GB external drive not being recognized by desk top or laptop? Any suggestions?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
It was OK until about a month ago. Now non of my computers recognise the Portable drive. It doesn't show in Manage also.
* the USB cable
* the power-adapter
Dec 22, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
I just got a 250GB Iomega eGo external hard drive and my Vista laptop will not recognize it in my computer but it is displayed as a mass storage device in device manager. I tried to update drivers through...
You may assign a drive letter to it by going to Start
  • right click computer
  • Select Manage
  • Go to disk management
  • select the drive It may be displayed as Disk 1 or Disk 2 (depends on your confug)
  • Change Drive Letter
  • Assign a Drive Letter
  • It should display on your computer
  • If you have not data on it, you may format it by going to Start and
    • Select Manage
    • right click on the drive and select format it.
    Oct 30, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
    All of a sudden, my external hard disk gone blank, all my data in the external disappeared ,..... any solution plsssss
    try this administrive tools computer management removable storage you might find something there good luck
    Aug 20, 2010 | Western Digital WD Passport 250GB Portable...
    250gb hard disk not working
    Your HD has an obvious problem. If it has power going to it and it isn't working then the HD needs to be replaced. Don't worry in many cases you can have the data retrieved from your old hard drive by using this online company that I highly recommend:
    http://www.gillware.com/
    Jul 05, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
    Laptop Won't Recognize External HD
    You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
    Then replug the drive again, and it should reinstall the drivers.
    Jules
    Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
    Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive Logo
    3,073 people viewed this question
    Top Beyond Micro Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
    Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
