Question about Brother MFC 420CN All-In-One InkJet Printer
Will not print in black
My printer will not print black on any of my picture .pls help
  • Anonymous Mar 26, 2009
    Yes, mine won't print yellow. The displays tells me that yellow is low, but the yelloe cartridge is full and if I replace it with another full one it tells me the same thing or that the cartridge is missing altogether. Test print comes up fine for every color but yellow, I've cleaned multiple times, I don't think there's anything wrong with the cartridge.
Brother 420 nc do not print in black original cartrige
Posted on Mar 03, 2009
I have replaced the print heads, and instead of printing red, which I made, it is printing black
DEAR FRIENDS; PLS DO THIS FIRST STEP FIRST
How to print nozzle check pattern iPF6100/iPF610/iPF710/iPF8000S/iPF9000S/iPF800/iPF9100
  1. Load unused paper.
  2. Press the Menu button to display MAIN MENU .
  3. Press or to select Test Print , and then press the button.
  4. Press or to select Nozzle Check , and then press the button.
  5. Press or to select Yes , and then press the OK button.The printer goes online and prints a test pattern.
Second later print out result pls compare you result print with my attachment picture.
replaced-print-heads-instead-printing-5j51azquscxy1hu2enwrxd50-4-1.jpg let say if anything color no same like example red = black,yellow = yellow black , cyan = dark or magenta = green.
this means got dirty on site purge unit and printhead unit. you need to call canon technician done services for you because i can't teach you how to clean the purge unit and print head unit scared you will spoil this both unit.
Hope can help you ,TQVM..
Apr 13, 2016 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
My printer does not print black characters although a new cartridge
pls do check the cartridge of your printer..maybe the black ink had been dry..and do pls..check and try to print again..and clean were the ink comes out.
Nov 14, 2011 | Lexmark X1195 All-In-One Printer
I have a HP Deskjet D4260 and when i print something using HP Deskjet D4200 series its black and white. I need the pictures to be in color
U must be using HP74, 75 cartridge for your printer.
There are few reasons you are getting black and white (gray)...for printing job.
1. No color ink.
- If you are out of color ink.. that's what it happens.
- check your ink level through control panel.
2. Printer set up. (I think this is pretty much the reason you are not getting color)
- First, check your printer setting.
If they are on gray scale mode, pls chang to color.
How? when you click the print (through file manu), there are option for control panel on your screen. Click that option and will see some detail option you can choose from size, print quality.
Among the print quality option, pls choose, color mode instead of gray mode. That's it.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Deskjet D4260 Printer
Black is not working in my brother mfc-240c printer
did you use genunie brother black ink cartridge?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Try the forum, there are alot of issues like yours.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
NO BLACK IN PRINT OUT
remove ur black catrige clean the contact surface
and replace properly and give a calibration ur problem will be solved
Dec 13, 2008 | Brother MultiFunction Center MFC-440CN...
C5280 printer
If you need the HP printer manual, pls try here > Setup Guide and Basics Guide.
If you need the manual of the software/application you are using to view the CD pictures, pls post back what it is that you are using. Alternately, you can use ACDSee, Adobe PhotoShop or any picture/image editing program to display and thereafter print the CD pictures.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 19, 2008 | HP Photosmart C5280 Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Feb 02, 2008 | Computers & Internet
Brother MFC 420CN All-In-One InkJet Printer Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
