Question about Apple iPod touch
My Ipod touch used to let me on anything on the internet but now, it says that the wifi is connected but i cant load anything on the internet. for example, when i try to get on youtube it says "you cannot connect to youtube" or something like that.
    Problem Solver:
  • 5 Answers
Select "Settings" and then "Wi-Fi."  Verify that the Wi-Fi is switched to the "On" position.  Also, verify that you are not connected to a "closed" connection (indicated by a lock icon next to the connection icon).
Posted on Mar 03, 2009
How do I connect to Internet?
I will help you to connect to internet from your iPod through WiFi.
Goto Settings-->WiFi ON-->it will search for the available accessible networks-->Tap the desired WiFi network-->your iPod is connected to internet.You can confirm this with a WiFi symbol e9083285-5bde-4821-8d34-3573b467f1f4.jpg in your status bar.
You can use Scanmyspeed.com to get the speed of your internet connection.
Sep 08, 2013 | Apple iPod touch
I can't connect my ipod to the internet
If you're having trouble with your wifi connection,try to follow this steps.
* iPod Touch shows no WiFi address (Tap Settings > General > About and scroll down to WiFi Address.
* iPod touch appears to be connected to a WiFi network but cannot use Wi-Fi for checking email and surfing the Internet.
* iPod Touch WiFi icon is showing as grayed out.
* When you tap Settings > WiFi and then you see no network entries.
If you have wireless problems,here is another method to do.
First you need to back up your data by syncing your iPod touch to iTunes. It is very important you do this before proceeding with the fixes below.
1. On the iPod Touch go to Settings > General > Reset and then select Reset Network Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 2 below.
2. On the iPod Touch go to Settings > General > Reset and then select Erase All Content and Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 3 below.
3. If the above fixes don't work then the only thing left is to restore the iPod touch software using iTunes which will erase all data on the device. So before restoring make sure you back up your data by syncing with iTunes.
After the restore is complete, you can resync with iTunes to load the data back to your iPod Touch. Now see if your device shows a WiFi address (tap Settings > General > About and scroll down to WiFi Address). If none of the above settings and fixes work ,then you might want to consider getting your iPod touch repaired by Apple.
Jul 20, 2011 | Apple iPhone Smartphone
My ipod touch won't connect to my home wifi- it has a password and i know it but it won't work when i try to connect to youtubesafari or anything else used with internet and it doesn't work.
You could try this: Go to Settings>General>Reset>Reset Network Settings.
After resetting that, try to connect to your WiFi again and enter the password and it should work.
For more iPod touch / iPhone tips, click here.
Jul 02, 2010 | Apple iPod touch
Wont connect to internet
To connect to the internet using wifi on the iPod touch, just follow the following steps:
Firstly, you should be in a wifi zone(an area where you can access wifi) or if you want to use it at your house with your residential internet connection, just get yourself a wifi router(shouldn’t cost more than $50-60) and configure it with your residential internet Once you are in a wifi zone, on your iPod touch, go to:
Settings > Wifi > Turn your wifi ON > Select a wifi network > Key in the WEP(only if asked for) > Connect
Once you’re done with this, you should get the IP settings and be able to surf the internet with no problem.
Note: At times when you’re too far away from the wireless router or a big thick brick wall is separating you and the wifi router, your iPod might show the network as available and you would also be able to connect to it, but surfing the internet using it would become a problem. If this happens to you, don’t worry, just move closer to the wifi router and it shouldn’t pose any other problems. Happy Surfing!
dont forget to rate me.....
Apr 05, 2010 | Apple iPod touch
Mine and my sisters ipod touch keep saying invalid argument everytime we try to get on the internet on it. If you know what wrong please anwser.
Hello there!
I might be able to help you on your case.
When you are connected to the wifi on your ipod touch do the followings
Settings>>wifi>>(you will see a blue arrow next to the wifi signal you are connected) tap on the blue button>>you will see couple of lines full with numbers.
If you see anything full less then 4 line then do these procedures.
After you press the arrow button you will see at the top part saying forget this netwok. Tap on that and then try to re-connect with the wifi.And then do the above procedures.
If it still doesnt solves your problem then this is because of your wifi connection.Try to reset your wifi connection or use another connection. Hope this will help you.
Jan 18, 2010 | Apple iPod touch
Cant unlock Wi-Fi connection so that i can go on the internet on my ipod
hello, i just solved my ipod wifi problem. first i turned off the computer and ipod. then held the rest button on the wireless router for 15 sec. next turn on computer. you will have to re set up the wireless connection (was no big deal). once i had internet on the pc i turned on my ipod and set up the wifi. worked perfect!
Nov 27, 2009 | Apple iPod touch
Ipod touch 8gb is connected to wifi but not internet
if the internet connection isnt strong it will not work for me so get closer.
Aug 30, 2009 | Apple iPod touch
My touch shows that I have a wifi connection, but i cant use it.
All you have to do to the ipod is go to settings, wifi and make sure its turned on in the same place you should see a list of wifi networks you can connect to just tap the one you want and the ipod will do its thing your done, but if you done all that and you ipod doesnt go online says connected but wont access the net, my guess is the wifi router you mite have some prob with that, make sure the internet ethernet cable is pluged into the modem plug not the numbered slots after this you should be good to go unless your wifi modem is new if so some req you to plug it to your computer via ethernet cable to program it first! Hope this helps
Jul 13, 2009 | Apple iPod touch
Ipod internet
well! man it`s that your ipod`s firmware or software has some corruption.i don`t know how it came but you can fix it by upgrading your ipod`s firmware using itunes and clicking on check for firmware or upgrade firmware.
even i do have ipod touch and i love it.
take care.
Jun 13, 2009 | Apple iPod touch
Apple iPod touch Logo
80 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
