Question about RCA Audio Players & Recorders
Cd player is not working. One day it was working and next day it wasn't. I guess a button was pushed and now we can't figure out. Cd player will not read or play cds
?: Does the cd spins? If it does the optical eye that reads the cd could be dirty. Clean the eye with cd lens cleaner. If the cd is not spinning the motor could be bad. Also some cd players can't read certain disks because of the density of the disk. Make sure you read the manual to see what cds are compatible with your boombox. I hope these solutions were helpful.
Good Luck
George
Posted on Mar 02, 2009
Every Button Switches Between Radio and CD
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Apr 18, 2014 | Panasonic CQ-DF203U CD Player
Cd player wont accept cd.s says load error
pull the player out but leave it connected. when you push the eject button,lightly tap on the top of the cd player, if there is one jammed, you may want to consider just getting a new cd player, it may do the same to your cd!
May 23, 2012 | Cars & Trucks
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
I have a panasonic SA-PM19 cd player. Last night as I was putting in a cd it wasn't on the tray all the way, I gave it a little push (too hard of a push) and the cd fell off the tray inside the cd...
remove the cover, and carefully remove the CD that fell in, use EXTREME care not to force anything,, everything in those is plastic, the clicking is probably the tracking rubbing on the cd that fell off
Jun 01, 2011 | Audio Players & Recorders
I just bought a used 2001 VW Passat. I loaded the 6 cd changer in the trunk, and pushed the CD button in the interior audio system and it played just fine. I listened to the CD twice after driving and...
Hi
Its probably not really worth repairing such an old system.
I would replace it with something more modern with better sound and control.
CD s are kinda out these days when most of your music and nav are on your smart phone .
However, you could remove cd player, remove covers and using cotton buds and solvent, gently clean the pickups for the laser.
Its probably full of crud.
Good luck
Roger
Apr 24, 2017 | 2001 Volkswagen Passat
CD stuck in player.
there are four screws on the front of the cd deck. take them off and remove the cd deck from the main unit. there is a total of for screws u need to remove to get the cd out from the top. two are near teh front holding the silver cover. remove them and slightly slight the cover forward and up to removethe next are towards the back. after all screws are removed gently lift the top cover making sure not to crack the load arms. remove disc and seal case again. hope this helps... cuz thats how i did it with no problems and btw mine is shot too
Dec 21, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Emerson pd6922
I could only find your manual in a site that sells them for a small price, better than throwing it away i guess... http://www.servicemanuals.net/(yg3cpj3vpfexhgvoxpibpy55)/results.aspx?type=OM&brand=148&model=PD6922
Apr 02, 2006 | Emerson PD6922 Boombox
849 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
