1) you must LUBE THE DECK BELT+ ROLLER BEARING.
2) Test the input voltage motor, if there are the MOTOR is faulty need REPAIR.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) SEE THE BLOCK DIAGRAM, whatever component can be faulty.
However you must test the power cord for short circuit between cable, repair, and look inside according the BLOCK, and proceed with logic, see any loose wires, or some wires touching the carcase, some filter, coil, power supply USE the VOM.
God bless you
motor smells hot and slows down when you get off it speeds up works great for about 25 to 30 min.
After about 30 minutes the track will go very slow and then start going very fast on its own and it smells like the motor or belt is burning
