Question about Generic Memory SP-220B Computer Speakers
DC voltage of SP-220B speakers?
What is the input DC voltage of SP-220B speakers? I don't have the power source. Please, don't tell me "buy the source". I can't do it. I live in Cuba.
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
Please tell me the input voltage and amperageof my speakers emachine model sp-30a
Output Values:
Output 9 VAC 200 Ma
Input values:
Input 120 VAC 60 Hz
I believe this is what you are looking for. Output voltage and amperage for the SP-30A speakers, as read on the tag. The output will be the sound out and capabilities. The input is going to be the standard US wall socket.
Apr 26, 2011 | Audio Players & Recorders
I need power adapter for creative inspire 4.1 4400
Any good off the shelf adapter should work, but make sure it reads:
INPUT: 100V to 240 V 50/60HZ OUTPUT:
12V DC, 2.9 Amps
Radio Shack or Best Buy is your best choices on finding one.
Thanks for choosing FixYa, If you find this helpful please vote and leave a comment.
Oct 14, 2010 | Creative Labs Inspire P7800 Computer...
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Jun 09, 2009 | JBL Media 100 Computer Speakers
Output voltage of 120volt AC brick & approx dimensions
Any PC speakers that have a AC plug pak attached can probably use 12V simply cut off the AC plug packs lead that goes to the speakers, and connect up 12V ya should be good to go.. some connect with a Phono Plug, and usually the Outer is Minus Voltage and the Centre is Plus Voltage .. they are also generally Diode protected so a reversal shouldn't cause too many probs... GL
Jul 29, 2008 | AOpen MA-691 Computer Speakers
Dell 20" monitor doesn't power up
I suspect Best Buy will most likely replace the monitor's entire power circuit. It's possible that you shorted out a fuse, the input transformer, or some other component in the monitor's power supply. The only way to tell for sure is to disassemble the monitor and check the circuitry visually and with a meter. This job is best left to a qualified technician.
Jun 13, 2008 | Gateway FPD2275W LCD Monitor
Generic Memory SP-220B Computer Speakers Logo
42 people viewed this question
Top Generic Memory Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Generic Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
