Question about Grundig YB 400PE AM/FM/SW Radio
Grundig yacht boy 400 radio does not work with mains operations
Grundig yacht boy 400 radio works with batteries. When batteries are removed and it is plugged to the wall through 9v adapter, message 'batt check' is flashing and radio does not work.
What's the problem?
Thanks
  • ensign07 Apr 11, 2009
    I was just given a Grundig Yacht Boy 400 to repair, nice looking radio.
    It is not the model we see around here, but there is a battery/AC adapter problem. With this one I think it is the multipole bandswitches.
    More to follow if anyone is interested, kwd...
    VE2KXD
Hello i have a grundig mini-300 radio , the volume control is stuck in high range . i have had many problems with this radio , i would love to talk with one of your representives . please call me at 585-313-3188,,thank you ,,,,nicholas ferrara
Posted on Aug 19, 2009
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Posted on Mar 27, 2009
Users manuel
ok can you tell me the main problem of your unit?
Oct 12, 2007 | Grundig Yacht Boy P2000 AM/FM/SW Radio
I don't know anything about grundig yacht boy 206
Go to this site and look for the type of documentation that interests you.
Jan 25, 2013 | Audio Players & Recorders
I have a grundig yacht bot 205, serial number 001143. I was wondering what year and where it was manufactured?
The Grundig Yacht Boy 205 was early 90s and could have been made anywhere. The Grundig Yacht Boy 205a was early to mid 60s and made in Germany.
Apr 28, 2011 | Grundig Yacht Boy 205 AM/FM/SW Radio
My ten year old Grundig Yacht Boy-------------------------------------------------------------------------------- When I play it on battery, it's fine. When I try to play it via an electric plug in the...
Probably more than $40 and that is the buy it now price on eBay at this link:
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=grundig+p2000&_sacat=See-All-Categories
Note that the opening price is only $25. Suggest you get a "new" used radio as a cost effective option. Alternative: buy (now relatively inexpensive) NiMH rechargeable batteries and run your P2000 on them.
Ringbearers
Apr 04, 2011 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Where can I find a replacement for a battery cover for the Grundig YP-P 2000?
The batteries you need are just regular AA batteries (also known as 'double A batteries'). In this product you need 3 of them. (AA = 1.5v -> 4.5V in this product) These can be bought in a local supermarket or electronics shop.
Sincerly
Jan 05, 2011 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Hi, I have a vintage GRUNDIG YACHT BOY 210 RADIO; Battery & Mains & sadly although the radio works on VHF it does not work on any other waveband not even static! Can you help? Thanks, Melvin...
HI Melvin. It is hard to diagnose issues like that over the net. But my first suspicion would be the bandswitch, if so equipped. Contacts can get dirty. I just had a look at your radio's photo, and it looks to be the age of a set that would have a bandswitch.
If you are experienced at romoving the rear of the cabinet, you may be able to see the band switch. It is full of contacts. You can use a contact cleaner, (make SURE it is safe to use on plastics) spray a little on the wafer switch, the work it back and forth.
[img]http://antiqueradios.com/gallery/d/109664-1/philco+band+1.JPG[/img] This is what a typical bandswitch looks like.
This is the most common reason a set will not pick up on some bands. Pushbutton operated radios is the next common cause of no reception on certain bands. I strongly doubt it would be from an open coil or other major issue.
Good luck an hope you get the set working.
Oct 02, 2009 | Grundig Yacht Boy P2000 AM/FM/SW Radio
RADIO TURNS OFF AUTOMATICALLY AS IF IT HAD NOT POWER TILST LOW BATTERY
There is no backup cell inside.
If you clean the contact spring with a cotton bud and soapy water that should get you going again. Don't forget batteries leak when old!
Service manual;
https://elektrotanya.com/grundig_yacht-boy-p2000.pdf/download.html
Aug 25, 2017 | Grundig Yacht Boy P2000 AM/FM/SW Radio
GRUNDIG
As sugn blinking on the top right?
You ran out of batteries, or if using AC, the adapter is wrong.
Jun 20, 2008 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Grundig YB 400PE AM/FM/SW Radio Logo
1,373 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
