Question about Adobe Photoshop CS for PC
How to know my authorize code??..
For my DB Query Analyzer
  • Sandip2u Mar 04, 2009
    i hv photoshop cs2.
    I changed different serial key using key generator.
    But important part is AUTHORIZATION code.
    Does anyone have this?
    I can't use photoshop without this.
    plz give.
  • Joselito Perez May 11, 2010
    What Photoshop Series Do you have. Change your PHOTOSHOP serial number
    Get a KEY Generator
You need to contact Adobe.com customer support.
Posted on Mar 19, 2009
SAS light is flashing and fork won't start! What does this mean?
Search Results
    Flashing SAS light & error 63. Discussion about troubleshooting ...
    www.forkliftaction.com/forum/thread.asp?trid=13333
    Jan 30, 2014 - 3 posts - ‎2 authors The long answer requires the Toyota analyzer to be connected to the SAS diagnostic port to get the following sub codes: 63-1, Forward and ...
Sep 24, 2015 | Cars & Trucks
What is a cholesterole analyzer?
A cholesterole analyzer is a machine that analyzes a sample of blood to check the level of cholesterole
Jan 08, 2014 | Health & Beauty
Do you know where I can get a DB board for the Panasonic PT-53WX54J?
Contact the nearest authorized service center for Sony at your town.
Jan 28, 2013 | Televison & Video
Circuit tester when plugged into 3 pronged plug, comes up with 2 green lights and 1 yellow light. There is no code on other side of tester to access this problem
Circuit analyzer does not show all possible problems, and tester might be defective.
Use analyzer on other outlets.
Buy another circuit analyzer.
Buy a multimeter at local hardware, and test for voltage, and continuity, and compare with known outlet that are functioning correctly.
For example outlet may be 240Volt instead of 120V.
Copy following links to see typical circuit analyzer and code:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
http://waterheatertimer.org/images/Outlet-polarity-200.jpg
May 22, 2012 | Leviton Electrical Supplies
SYntax error in from clause
Hi
Try to run the record set query (the one rs.open uses ) directly in the db you are using .
If you are not sure what is the query concatenate it into variable and get the full query just before you open the record set.
once you do that you will get better idea of what is wrong with the query .
Jul 20, 2009 | Microsoft Visual Basic 6.0 for PC
How to write a code of a combobox
Try this code:
Combo-BOX - Abstraction With function you can retrieve the combo-box
structure with its data
<?php
function GetCombo_Where($db, $nombre, $tabla, $campo_lista, $campo_graba,
$campo_seleccionado,$valor_seleccionado,$where)
$query="SELECT * FROM $tabla ";
$query.=($where)?"WHERE ".$where:"";
$db -> query ($query);
$cant_registros = $db -> num_rows ( );
$string = "<select name=".$nombre.">";
if ($seleccionado=="")
$string .="<option></option>";
for ($i=1;$i<=$cant_registros;$i++)
$db -> next_record ( );
$value = $db -> Record[$campo_graba];
if ($valor_seleccionado == $db -> Record[$campo_seleccionado])
$string .= "<option selected value = ".$value." >";
else
$string .= "<option value = ".$value." >";
$string .= $db -> Record[$campo_lista];
$string .= "</option>";
$string .= "</select>";
return $string;
hope this helps.
Thanks
Shafi
May 08, 2009 | Computers & Internet
Vb 6.0 to oracle connectivity problem
Your SQL query does not look valid. Test the query in SQL Query analyzer, and then once it is working, copy it into your VB source. You will of course then need to make the query a string that VB will accept.
Mar 23, 2009 | Microsoft Computers & Internet
They are putting the car true a comp to check what is wrong with the car ,but the mecanic that is doing it need one spicific code for the lancer ,to put in the comp to check the car can you help?
Without knowing the make and model of the analyzer they are using, there is no way to help you.
The maker of the analyzer may have a web site where you can find codes missing from the manual they have.
Sep 02, 2008 | Mitsubishi Lancer Cars & Trucks
Ms access
Stored Procedures don't exist in MS Access. You do have the following options though. Queries, which are just select or action queries. VB Code, which you can write using Query Objects as if you were writing a Visual Basic application. These can be Functions or Subroutines. In these, you would use the standard programming techniques with while and for loops, etc.
You can create complex situations combining the two of these. A function in the VB code area can accept through parameters, the single values (line by line, record by record) in a query and act on them and manipulate the values.
For example: create a query that does a select phone from address. Create a function in vb called public function StripDashesInPhone(Phone as string) which then uses VB coding to strip dashes from each phone value passed in. To make it all work, in the query on one of the field columns put "NewPhone: StripDashesInPhone([Phone])" and for every record processed in the query, the function is called with the [Phone] field value passed in to the function and the action is processed and returned.
Other than writing a function that is activated by a form button click, which opens the current db and opens a table and process it, just like in VB, this is about as close to cursors and oracle procedures as you get.
I wish it was more, but ...
Oct 09, 2007 | Microsoft Office Standard for PC
SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Aug 30, 2007 | Microsoft SQL Server 2000 Standard Edition...
Adobe Photoshop CS for PC Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
