Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Free agent doesnt encrypt
When i create an ecryption folder and drag files to it, it doesn't encrypt them. i can turn off seagate manager, unplug the ext drive, even restart the computer, but when i go back to seagate manager, select security, encryption and open encryption folder it opens without asking for password. all files are easily accessible to anyone. I can also acess the drive and folder from windows explorer, NEVER askes for a password????
I Posted a solution to this prob but i don't see it anymore. Your ext drive is Encrypting your folder. It just knows you're the one using it. If I took it and plugged it in to my computer, it would recognize my user name as t0mthab0mb and prompt me for the password. Try it. Create a different user account on your computer, then try to access the encryption folder from the new account.
Posted on Mar 12, 2009
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
We have the seagate free agent and don't know where to go to drag our items from main hard drive to the seagate
Double click on My Computer expand the "C" drive / minimise and simply drag from one drive to the other.
Dec 23, 2009 | Seagate Free Agent Go Small 12 GB USB...
How do I transfer files to my seagate free agent?
Just left-click the file or folder you want to copy, choose copy.
Open My Computer and find the external drive, double click, once the folder opens just right-click and choose Paste.
That's pretty much it....or you could also drag files / folders to the drive.
Hope this helps.
Nov 24, 2009 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Multisystem ulility plus supporting OS
If you use the utility that comes with the drive, you will be able to access all of your files and folders that you encrypt on the drive privided that you don't forget your password. If you want to make sure that the drive is protable (can be used on multiple systems), you need to make sure you enable Travel Mode with the Seagate Manager software. You must remember the password in order to access your files.
Jul 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Free Agent Go Problem
Install the seagate manager on a different computer and decrypt the files there first then move it back to your computer using the basic copy/cut and paste.
May 27, 2009 | Seagate FreeAgent Pro 500GB External USB...
Seagate free agent 1.5 terabyte will not stay connected to my computer When I connect my free agent to my computer (Asus laptop with Vista Home premium) all the folders show up and I can access files for...
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
Jun 06, 2017 | Seagate Free Agent Go Small 12 GB USB...
Seagate Free Agent 1.5TB doesn't encrypt
I was fumbling around with this as well. I found a manual on my external drive itself. I had to read through it carefully before i saw a small note.
Note: After you open your Encryption folder on the first computer and user account with which
you use Seagate Manager, it will be saved on that computer so that will never need to
enter it again. When opening your Encryption folder from another computer or user
account, however, you will need to enter your password.
I have yet to test it by creating another user account, then attempting to access the files. I am confident that this is the answer.
Mar 01, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
284 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
