Question about HP Pavilion L2335 23" LCD Monitor
Remove Monitor Cover for HP L2335 LCD
Hi, How do I remove monitor cover for an HP L2335 LCD monitor? I've removed stand but can't find any screws!
SOURCE: need to remove dell e193fpc flat panel covers to repair
First remove the stand. Then at the bottom of the monitor there are two small openings an inch or two from each edge. Starting there with WIDE flat blade screw driver (or a couple of them) it IS possible to pop the catches that hold the back of the case to the front. You have to go around the case very carefully popping each catch and preventing the areas you have opened from becoming re-latched. I found some wood popsicle sticks good for that.
If you search for "LCD Monitor Repair" you can find sites that have video's of several Dell models (but not this exact one) any that use the "pop open" case are pretty much similar.
One note after you get inside. The power supply board had the WORST solder job I have seen in a long time. The failure in the unit I repaired was due to open solder joints on the hi-voltage transformers taking out the power transistor's that drove them. It took me two months, but I found some replacement transistors on ebay and after resoldering many of the joints on the board it the monitor works fine.
I attribute part of the failure to the use of Lead free solder which is becoming common in all consumer electronics. It makes for brittle connections that fail easily and there is also the issue of tin whisker growth that will hit in a few years down the road.
Posted on Mar 16, 2009
skotkolr
  • 558 Answers
SOURCE: Removing Stand from LCD Monitor
remove the obvious screws that hold the stand you can see that from the rear of the monitor stand
Posted on May 10, 2008
  • 13 Answers
SOURCE: Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Posted on Jan 03, 2009
micromend
  • 748 Answers
SOURCE: Remove cover
Did you remove the base from the back? If so, there are two stating slots at the bottom of the screen. A fine blade screwdriver will release these tabs. Once down, the front bezel will pull away but you'll need a flat blade screwdriver (preferably made out of plastic). Slide this screwdriver between the front bezel and the screen frame which is metal. Don't allow the driver to get next to the screen because it will scratch easily. Using the driver you'll be able to pry away the bezel from the rear.
Posted on Mar 28, 2009
  • 152 Answers
SOURCE: Have an HP LCD Monitor with a broken on/off switch.
j1hoo2, You will just have to go to YOUTUBE and search for things like::: lcd monitor disassembly or lcd monitor repair, or bad caps in lcd monitors, or repair of monitor SMPS/INVERTER power supplys. Yes!!! I have seen a couple of vids that show how to unsnap the rear plastic cover from the front bezel. That is the hardest part to do after removal of the monitor PEDESTAL. I'm louie12fix on fixya, or lmistyrel@ aol.com
ps I've also heard that really dull table knives may work and also an old credit/swipe-card might work also.. I mean did an elephant step on the monitor on/off button???? Come-on, their not supposed to FAIL !!!
Posted on Apr 24, 2009
How to remove acer gd245hq monitor cover to replace screen
How To Remove Acer Lcd Stand - YouTube
? 0:40
www.youtube.com/watch?v=i8TZSoUnk1s
Feb 10, 2011 - Uploaded by rakka1988 The "cowling" or plastic cover over the hinge where the stand enters the back of the monitor just LOOKS like it's part of the back of the monitor.
Reparar monitor ACER GD245HQ - YouTube
? 1:12
www.youtube.com/watch?v=Muz6BU7l9Ys
Jul 5, 2012 - Uploaded by C?sar ?vila
La mitad derecha del monitor no se ve?a, estaba negra, la otra mitad funcionaba bien. Cambi? todos los ...
Oct 16, 2015 | Acer Computers & Internet
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
How to remove the screen bezel from the HP L2335?
ssocko123, If you plan on replacing the switch let me suggest that you go watch some video clips of lcd monitor disassembly at YOUTUBE!!!
The longer (6-12minute) ones will be more helpful. Stay away from the usless ones where they shoot them with guns or use 10lb crow bars to open them!! Have fun guy. 12fixlouie if this was of some help please rate on fixya.....
Nov 11, 2009 | HP Pavilion L2335 23" LCD Monitor
How do I remove the base stand fro my Neovo F-17,
You need to remove the two plastic covers the cover up the hinges mounting screws, which are attached to the back of the monitor.
Oct 26, 2009 | Neovo F-17 W (White) 17 in. Flat Panel LCD...
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Acer LCD (AL1917W)
After removing the back cover screws that you saw, ok, there is a screw under the stand holder. Remove the cover that covers the stand holder joints. you can remove it using a flat head screw driver, it is removeable only it appeares stuck to the back cover. After you unscrew, use flat head screw driver and carefully by pushing to the side of the LCD bend. Carefull you might break the cover. Good Luck.
Oct 03, 2008 | Acer AL1917W LCD Monitor
How to dismount the monitor
What stand do you have? If it is screwed to the back with 4 or 3 screws, they must be removed first. look along the bottom edge and you will see 3 slots where the two outer cases match up. Put a flat screwdriver into the opening and twist, follow all the way around until you can remove the back half. Cut the tape holding the flat wire and remove the front half to remove the printed board under the front cover. You should now be inside the case. Remove the screws to remove the steal cover to find the printed boards under it. Reinstall is the reverse.
Sep 13, 2007 | LG Flatron L1715S 17" LCD Monitor
HP Pavilion L2335 23" LCD Monitor Logo
760 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
