Question about HP Office Equipment & Supplies
How to check ink levels on deskjet 5150?
How to check color ink levels on deskjet 5150?
    President:
  • 2,692 Answers
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
Since upgrading to Windows 7 and having to relaod the driver for hp deskjet 5150 I can no longer get my ink levels, ability to clean or calibrate the printer, etc. What do I need to do to get these...
You need to download a patch from HP. Go tot he HP Print Software Patch When Upgrading Vista to Windows 7
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77751-1&cc=us&lc=en&dlc=en&product=304431&tmp_track_link=ot_search
This patch will fix known problems with the following features and functionality:
•HP Print Status
•Toolbox
•Ink Levels
•Solution Center
•HP Scan (All-in-One)
•Front panel scan button (All-in-One)
Trust this is helpful. Please vote. :)
Dec 15, 2010 | HP DeskJet 5150 InkJet Printer
No color
try to head clean your printer..
follow this steps
1.click start
2.than click printers&faxes
3.right click on hp deskjet printer logo
4.select printing preference tab
5. click on maintenance
6. click on head clean
do it once and try to print some picture with best quality print setting.. and than try to print normaly again.. repeat the steps until the printer normal.
hope this help..
Apr 30, 2010 | HP DeskJet 5150 InkJet Printer
I cannot find how to access the ink level on my HP 5150. There is no "service" tab on my "printer preference" window.
let me tell u this means ur printer full feature driver is not installed in ur computer to install the driver u can try this link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=304431&lc=en&cc=us&dlc=en&lang=en&cc=us
and the other way u can check the accurate ink level in by printing a self test page
  1. Ensure the printer is turned on.
  2. Press and hold the Power button.
  3. While holding the Power button, press and release the Resume button four (4) times.
  4. Release the Power button. A self-test page will print.
Feb 23, 2010 | HP DeskJet 5150 InkJet Printer
Hp deskjet 5150 just replaced both inks...black
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | HP DeskJet 5150 InkJet Printer
Hp 5150 deskjet says that it is low on color ink
The low ink warning is actually normal for remanufactured cartridges. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. The prints should still be the same quality. You can either press the "Resume" or "OK" button to continue printing, or go into your printer settings and manually disable the ink level indiactor.
Feb 07, 2009 | HP DeskJet 5150 InkJet Printer
Ink levels
  1. Right-click the Printer icon on the Taskbar.
  2. Click Open Toolbox .
  3. check ink level
Nov 01, 2007 | HP DeskJet 5150 InkJet Printer
3,259 people viewed this question
Ben Johnson
