Question about LG DLG7188 Gas Dryer
Dryer takes hours to dry ever since I converted to propane.
I put the dryer on to dry a load and literally have to do this at least 3 times before load dries. I moved and converted to propane worked great a couple times then not again. I've checked connection. I checked dryer to make sure it was getting hot. Not sure what to do next. It takes all day to do just a bit of laundry. And I'm getting scared of propane bill.
  • 686 Answers
Check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Posted on Mar 01, 2009
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
Mar 02, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
My dryer is heating up but isn't drying the clothes
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
Sep 09, 2009 | Whirlpool Dryers
Aouto dry timer doesnt shut off system when clothes dry
It could be as simple as cleaning the sensors with rubbing alcohol. Build up from dryer sheets will cause erratic operation. It could also be a bad gear or dirt in the timer. Eric
Jun 19, 2009 | Whirlpool Dryers
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 | Dryers
How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
MAGIC CHEF DRYER CYE2000AYW
eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Mar 05, 2008 | Dryers
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
Open Questions:
LG DLG7188 Gas Dryer Logo
216 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
